0014371 | ParaView | (No Category) | public | 2013-10-29 15:46 | 2015-01-11 08:23 | ||||
Target Version | 4.1 | Fixed in Version | 4.1 | ||||||
Summary | 0014371: Turn off "Automatically rescale transfer functions to fit data" when supplying a custom range | ||||||||
Description | The features for supplying a custom range to the color map and automatically rescaling used to be mutually exclusive. They no longer are. Now when you supply a custom range, if you are not very careful your custom range will go away as soon as you do something else (like add a filter). To see this in action, do the following. 1. Load disk_out_ref.ex2. Load all variables. Apply. 2. Color by Pres 3. Open the Color Map Editor 4. Click Rescale to custom range 5. Set range from 0 to 0.01. Make sure the color map is updated. 6. Add Extract Surface filter. Apply. After step 6, the custom range we entered has been obliterated. This is surprising behavior. To make the behavior more predictable, the "Automatically rescale transfer functions to fit data" option should be deselected when a custom range is entered. This deselection should happen after "Rescale" in the Set Range dialog. If the user hits cancel, then the automatically rescale option should remain the same. | ||||||||
Project | Sandia | ||||||||
Topic Name | 14371_fix_color_function_rescale | ||||||||
Relationships | ||||||
(0031772) Alan Scott (manager) 2013-10-29 17:40 |
Marking todo, since this is affecting climate simulations. |
(0031784) Utkarsh Ayachit (administrator) 2013-10-30 16:04 |
commit 2e2c51ecadf514c436387f8114f07adcef6bf79e Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Wed Oct 30 16:03:04 2013 -0400 BUG 0014371: disable LUT rescale when user sets a custom range. Disable automatic LUT range rescale when user sets a custom range or a temporal range. Change-Id: Id8fd28b51207a7e50fac2cc01aa398c7478b6e90 |
(0031811) Utkarsh Ayachit (administrator) 2013-11-01 13:11 |
SUMMARY --------------------------------------------- Topics merged into master: selection_enhancements pvweb-fix-script-path fix_chart_interactions 14376_fix_settings_dialog 14375-in-situ 14371_fix_color_function_rescale 14287_fix_time_and_find_data --------------------------------------------- Topics reverted from next: paraview-web-client-tests vtkweb-url-arg-parsing *NOTE* these topics were reverted since the referenced VTK topics were not merged in VTK master |
2013-10-29 15:46 | Ken Moreland | New Issue | |
2013-10-29 17:39 | Alan Scott | Relationship added | has duplicate 0014334 |
2013-10-29 17:40 | Alan Scott | Note Added: 0031772 | |
2013-10-29 17:40 | Alan Scott | Status | backlog => todo |
2013-10-30 15:49 | Utkarsh Ayachit | Project | TBD => Sandia |
2013-10-30 15:49 | Utkarsh Ayachit | Target Version | => 4.1 |
2013-10-30 15:49 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2013-10-30 16:04 | Utkarsh Ayachit | Topic Name | => 14371_fix_color_function_rescale |
2013-10-30 16:04 | Utkarsh Ayachit | Note Added: 0031784 | |
2013-10-30 16:04 | Utkarsh Ayachit | Status | todo => gatekeeper review |
2013-10-30 16:04 | Utkarsh Ayachit | Fixed in Version | => git-next |
2013-10-30 16:04 | Utkarsh Ayachit | Resolution | open => fixed |
2013-11-01 13:11 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2013-11-01 13:11 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-11-01 13:11 | Utkarsh Ayachit | Note Added: 0031811 | |
2013-11-01 13:17 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
2013-11-04 13:51 | Ken Moreland | Status | customer review => closed |
2015-01-11 08:23 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master a0ce57a7 |
2015-01-11 08:23 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 2e2c51ec |
