0014342 | ParaView | (No Category) | public | 2013-10-21 20:37 | 2014-01-11 08:39 | ||||
Assigned To | Dan Lipsa | ||||||||
Target Version | Fixed in Version | 4.1 | |||||||
Summary | 0014342: Integrate variable fails with empty servers | ||||||||
Description | Sorry, not a good summary. When you try to integrate variables, and you don't have data in each remote server (each pvserver), integrate variables filter fails. Time for an example: * Linux, master, 8 remote servers. * Open g1s1-10fps.e.16.*. All variables on. Apply. * Integrate variables. Apply. Go to Cell Type in the spreadsheet view. Notice that there is at TEMP summed variable, that is around 19903 degrees. This is correct. * Close the Integrate variables filter. * Unselect block 1 and 3, leaving only block 2 selected. Apply. Using the Process Id Scalars filter, you can see that this block only goes into one pvserver. 7 are left empty. * Integrate variables filter. Apply. Go to Cell Type in the spreadsheet view. Notice there is no TEMP summed variable. This is a bug. | ||||||||
Project | Sandia | ||||||||
Topic Name | 14342-integrate-empty-servers | ||||||||
(0031825) Utkarsh Ayachit (administrator) 2013-11-04 13:08 |
Adding more details: + the issue happens only when the root node doesn't have the dataset. Another way to reproduce this issue is follows: + Open disk_out_ref.ex2 (load all variables) when connected to a parallel pvserver. + Apply D3 filter + Apply "Process ID Scalars" filter + Apply Threshold to pass cells where "Process ID" is in a range > 0. + Now apply "Integrate Variables" filter and you'll see the issue reported. |
(0031881) Dan Lipsa (developer) 2013-11-27 13:49 |
Paraview commit: commit 9f9d72ed834101eeda1a4226ae0a566c27f4a739 Author: Dan Lipsa <dan.lipsa@kitware.com> Date: Tue Nov 19 14:27:49 2013 -0500 Fix IntegrateAttributes so it works when node 0 has no data. This may happen after a Threshold. We find out the minimum node that has data and send it to node 0. Change-Id: Id0dfa4b02b0b4a1cb484525e0116fd8be9fd914b |
(0031894) Utkarsh Ayachit (administrator) 2013-12-04 11:56 |
Topics merged into master: 14295_search_text 14342-integrate-empty-servers (VTK) 14350-opacity-interpolate-scalars 14424_fix_copy_paste 14428_expand_valid_range export-tensor-glyph fix-streaming-behavior fix_SLAC_tools_segfault improve-selection-inspector make-sciberquest-module pv-collaboration-fix (VTK) pvweb-doc-update pvweb-fix-start-test-names pvweb-group-pattern-option (VTK) pvweb-integrate-test-packages-alternate (VTK) pvweb-session-manager-url-update pvwev-select-box-for-viewport-selection sqtk-cmake-warnings (VTK) update_vtk_master |
(0032002) Alan Scott (manager) 2013-12-17 21:16 |
Tested with Utkarsh's directions. In this case, Temp was on point. Tested Linux, master, remote server. |
2013-10-21 20:37 | Alan Scott | New Issue | |
2013-11-04 11:20 | Utkarsh Ayachit | Assigned To | => Cory Quammen |
2013-11-04 13:08 | Utkarsh Ayachit | Note Added: 0031825 | |
2013-11-04 13:08 | Utkarsh Ayachit | Assigned To | Cory Quammen => Dan Lipsa |
2013-11-18 11:18 | Dan Lipsa | Topic Name | => 14342-integrate-empty-servers |
2013-11-18 11:18 | Dan Lipsa | Status | backlog => active development |
2013-11-27 13:49 | Dan Lipsa | Note Added: 0031881 | |
2013-11-27 13:49 | Dan Lipsa | Status | active development => gatekeeper review |
2013-11-27 13:49 | Dan Lipsa | Resolution | open => fixed |
2013-12-04 11:55 | Utkarsh Ayachit | Fixed in Version | => git-next |
2013-12-04 11:56 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-12-04 11:56 | Utkarsh Ayachit | Note Added: 0031894 | |
2013-12-17 21:16 | Alan Scott | Note Added: 0032002 | |
2013-12-17 21:16 | Alan Scott | Status | customer review => closed |
2014-01-09 08:47 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2014-01-11 08:39 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
