0014325 | ParaView | (No Category) | public | 2013-10-14 17:43 | 2013-11-01 13:17 | ||||
Assigned To | Alan Scott | ||||||||
Target Version | Fixed in Version | 4.1 | |||||||
Summary | 0014325: depth buffer with contours and alpha error | ||||||||
Description | There is a depth buffer bug with contours and alpha. It is replicated as follows: * Remote server, 8 servers, master, Linux. (I bet you can see it local server, although it may not be as obvious.) * Wavelet, apply. * Contour. Delete the contour that is there. Generate new contours (default - which makes 10 of them). Apply. * Turn off visibility of the Wavelet. * Change contour's coloring to Normals. Change "Magnitude" to "X". * -X * Now, change the opacity to 0.999. Click somewhere else, such as point size. Although there should be no change, the image will change - and look horrible. Z buffer problems will be all over - with black lines triangles bleeding through, blue bleeding through, etc. If this is hard to replicate, ask me and I can make a screenshot. | ||||||||
Project | Sandia | ||||||||
(0031710) Alan Scott (manager) 2013-10-21 16:39 |
This report is actually showing up bugs in older versions of Mesa. I believe it is representative of any video card or driver issue related to Depth Pealing. On newer versions of Mesa (remote server), and NVidia cards (Linux), this bug doesn't exist. Closing. |
2013-10-14 17:43 | Alan Scott | New Issue | |
2013-10-21 16:39 | Alan Scott | Note Added: 0031710 | |
2013-10-21 16:39 | Alan Scott | Status | backlog => closed |
2013-10-21 16:39 | Alan Scott | Assigned To | => Alan Scott |
2013-10-21 16:39 | Alan Scott | Resolution | open => fixed |
2013-10-21 16:39 | Alan Scott | Fixed in Version | => git-master |
2013-11-01 13:17 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
