0014299 | ParaView | (No Category) | public | 2013-09-25 11:58 | 2015-01-11 08:23 | ||||
Target Version | 4.1 | Fixed in Version | 4.1 | ||||||
Summary | 0014299: Contour panel not updating correctly | ||||||||
Description | Steps to reproduce (make sure "Auto Apply" is not ON) + Wavelet, Apply + Contour, Apply -- all well so far + Click on the button below the "-" sign with the tooltip "add a range of values" to add a range of values to contour with. Accept the default values in the popup dialog. BUG --> while the IsoSurfaces widget updates to show the new values, the Apply button doesn't go green! | ||||||||
Project | Sandia | ||||||||
Topic Name | 14299_fix_contour_panel | ||||||||
(0031641) Utkarsh Ayachit (administrator) 2013-09-26 16:42 |
commit bffda434dfc82c531db50ef93602471660b7f7c4 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Thu Sep 26 16:41:38 2013 -0400 BUG 0014299: Fixed missing "modified" notification. pqScalarValueListPropertyWidget wasn't firing appropriate signal when a range of values were added to the widget. Fixed that. Change-Id: I70581a3aacaddcc760290bc5d5b519c20d57de43 |
(0031665) Utkarsh Ayachit (administrator) 2013-09-30 09:21 |
SUMMARY --------------------------------------------- Topics merged into master: 0014284_fix_color_map 13797_fix_chart_sizes 14287_fix_proxy_delete 14289_fix_extent_issues 14299_fix_contour_panel 14309-chart-selection-buggy fix_python_windows_coprocessing (VTK) forward-to-vtk-master (VTK) parallel-surface-lic-pv sqtk-fix-some-issues |
(0031790) Alan Scott (manager) 2013-10-30 22:27 |
Tested local server, master, Linux. |
2013-09-25 11:58 | Utkarsh Ayachit | New Issue | |
2013-09-25 11:59 | Utkarsh Ayachit | Target Version | => 4.1 |
2013-09-26 16:42 | Utkarsh Ayachit | Topic Name | => 14299_fix_contour_panel |
2013-09-26 16:42 | Utkarsh Ayachit | Note Added: 0031641 | |
2013-09-26 16:42 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2013-09-26 16:42 | Utkarsh Ayachit | Fixed in Version | => git-next |
2013-09-26 16:42 | Utkarsh Ayachit | Resolution | open => fixed |
2013-09-26 16:42 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2013-09-30 09:21 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-09-30 09:21 | Utkarsh Ayachit | Note Added: 0031665 | |
2013-10-21 08:16 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2013-10-30 22:27 | Alan Scott | Note Added: 0031790 | |
2013-10-30 22:27 | Alan Scott | Status | customer review => closed |
2013-11-01 13:17 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
2015-01-11 08:23 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master cce5465c |
2015-01-11 08:23 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master bffda434 |
