0014292 | VTK | (No Category) | public | 2013-09-24 04:23 | 2015-02-09 15:59 | ||||
Reporter | James Prichard | ||||||||
Assigned To | Ben Boeckel (Kitware) | ||||||||
Product Version | 6.0.0 | ||||||||
Target Version | Fixed in Version | 6.2.0 | |||||||
Summary | 0014292: MinGW64 build on Windows7 error in vtkWin32VideoSource::Initialize() call to vtkSetWindowLong (not Ptr) | ||||||||
Description | Initial problem reported below - complained about the cast. I tried removing these casts, so passing 'this' as native size which reveals WINUSERAPI LONG WINAPI SetWindowLongA(HWND hWnd,int nIndex,LONG dwNewLong) is called. MSDN suggests SetWindowLongPtr() for 64-bit apps. == build system output == [ 93%] Building CXX object IO/Video/CMakeFiles/vtkIOVideo.dir/vtkWin32VideoSource.cxx.obj /IO/Video/vtkWin32VideoSource.cxx: In function 'LONG vtkWin32VideoSourceWinProc(HWND, UINT, WPARAM, LPARAM)': /IO/Video/vtkWin32VideoSource.cxx:105:44: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] (vtkGetWindowLong(hwnd,vtkGWL_USERDATA)); ^ /IO/Video/vtkWin32VideoSource.cxx: In member function 'virtual void vtkWin32VideoSource::Initialize()': /IO/Video/vtkWin32VideoSource.cxx:277:71: error: cast from 'vtkWin32VideoSource*' to 'LONG {aka long int}' loses precision [-fpermissive] vtkSetWindowLong(this->Internal->ParentWnd,vtkGWL_USERDATA,(vtkLONG)this); ^ In file included from /IO/Video/vtkWin32VideoSource.cxx:31:0: /IO/Video/vtkWin32VideoSource.cxx:342:52: error: cast from 'vtkWin32VideoSource*' to 'long int' loses precision [-fpermissive] if (!capSetUserData(this->Internal->CapWnd,(long)this)) ^ IO/Video/CMakeFiles/vtkIOVideo.dir/build.make:82: recipe for target `IO/Video/CMakeFiles/vtkIOVideo.dir/vtkWin32VideoSource.cxx.obj' failed | ||||||||
Tags | hackaton | ||||||||
Project | TBD | ||||||||
(0033517) Ben Boeckel (Kitware) (developer) 2014-10-02 15:03 |
Pushed to Gerrit (untested personally; will try it out on my Windows machine later) http://review.source.kitware.com/#/t/4780 [^] |
(0034200) Ben Boeckel (Kitware) (developer) 2015-02-09 15:59 |
This has been merged. |
2013-09-24 04:23 | James Prichard | New Issue | |
2014-10-02 14:59 | Ben Boeckel (Kitware) | Assigned To | => Ben Boeckel (Kitware) |
2014-10-02 14:59 | Ben Boeckel (Kitware) | Tag Attached: hackaton | |
2014-10-02 15:03 | Ben Boeckel (Kitware) | Note Added: 0033517 | |
2014-10-02 15:03 | Ben Boeckel (Kitware) | Status | backlog => gerrit review |
2015-02-09 15:59 | Ben Boeckel (Kitware) | Note Added: 0034200 | |
2015-02-09 15:59 | Ben Boeckel (Kitware) | Status | gerrit review => closed |
2015-02-09 15:59 | Ben Boeckel (Kitware) | Resolution | open => fixed |
2015-02-09 15:59 | Ben Boeckel (Kitware) | Fixed in Version | => 6.2.0 |
