0014289 | ParaView | (No Category) | public | 2013-09-20 09:43 | 2015-01-11 08:23 | ||||
Target Version | Fixed in Version | 4.1 | |||||||
Summary | 0014289: vtkPythonProgrammableFilter doesn't work correctly in parallel | ||||||||
Description | Try this: + ParaView with parallel pvserver + Open wavelet; Apply; Surface; Color By vtkProcessId -- You'll see data paritioned as expected. + Create Programmable Filter; Apply; Color By vtkProcessId -- The color switches to a single color -- all processes are working on all data!!! That's a bug. | ||||||||
Project | Sandia | ||||||||
Topic Name | 14289_fix_extent_issues | ||||||||
(0031650) Utkarsh Ayachit (administrator) 2013-09-27 15:06 |
commit 6ebe5e0fa5cf783c0606ea813e75528559e32dfb Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Fri Sep 20 10:39:10 2013 -0400 BUG 0014289. Fix extent issues with programmable-filter. vtkPythonProgrammableFilter created a OnePieceExtentTranslator by default. That resulted in all processes requesting the whole-extent on each of them which resulted in BUG 0014289. This was done so to handle a use-case where we used vtkPythonProgrammableFilter to generate structure-data for operations like histogram or stats. VTK has since then moved to using vtkTable for such operations hence the need for OnePieceExtentTranslator becomes moot. While, users using vtkPythonProgrammableFilter without expecting to change the process extents when dealing with partitioned image data have strated to grow. Hence changing the default behavior of the filter to be as expected -- i.e. not muck with data extents -- in parallel. Change-Id: I2e8d695bd369d1a7ba4b6b5d64eb3ecb03440e6a |
(0031664) Utkarsh Ayachit (administrator) 2013-09-30 09:21 |
SUMMARY --------------------------------------------- Topics merged into master: 0014284_fix_color_map 13797_fix_chart_sizes 14287_fix_proxy_delete 14289_fix_extent_issues 14299_fix_contour_panel 14309-chart-selection-buggy fix_python_windows_coprocessing (VTK) forward-to-vtk-master (VTK) parallel-surface-lic-pv sqtk-fix-some-issues |
(0031792) Alan Scott (manager) 2013-10-30 22:34 |
Tested remote server, Master, Linux. |
2013-09-20 09:43 | Utkarsh Ayachit | New Issue | |
2013-09-20 10:50 | Utkarsh Ayachit | Topic Name | => 14289_fix_extent_issues |
2013-09-20 10:51 | Utkarsh Ayachit | Summary | vtkPythonProgrammableFilter doesn't work correctly in ParaView => vtkPythonProgrammableFilter doesn't work correctly in parallel |
2013-09-27 15:06 | Utkarsh Ayachit | Note Added: 0031650 | |
2013-09-27 15:06 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2013-09-27 15:06 | Utkarsh Ayachit | Fixed in Version | => git-next |
2013-09-27 15:06 | Utkarsh Ayachit | Resolution | open => fixed |
2013-09-27 15:06 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2013-09-30 09:21 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-09-30 09:21 | Utkarsh Ayachit | Note Added: 0031664 | |
2013-10-21 08:16 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2013-10-30 22:34 | Alan Scott | Note Added: 0031792 | |
2013-10-30 22:34 | Alan Scott | Status | customer review => closed |
2013-11-01 13:17 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
2015-01-11 08:23 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 99618d96 |
2015-01-11 08:23 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 6ebe5e0f |
