0014288 | ParaView | (No Category) | public | 2013-09-18 21:47 | 2015-01-11 08:23 | ||||
Product Version | git-next | ||||||||
Target Version | Fixed in Version | 4.1 | |||||||
Summary | 0014288: Color editor goes black | ||||||||
Description | I have found a case where the color editor screen is showing black, and changing the color table. This is bad - it is keeping me from working on weather simulations. * Master, Linux, local server. * Open Whipple_Shield.exo.4. All variables on. Apply. * Cell Data to Point Data. Apply. * Open a Color Editor. Enable opacity mapping for surfaces. Update. * Add a calculator filter. Result array name: Pres2. Formula: PRESSURE. Apply. *In the color editor window, use log scale when mapping data to colors. Enable opacity maping for surfaces. Click on the sloping line, in the middle - creating a point. * Now, in the pipeline browser, turn CellDataToPointData visible. * Highlight the calculator, then the cell data to point data filter, then the calculator, then the cell data.. Watch the Color Map Editor. It will randomly place points in the horizontal colorbar, and make the right side of the mapping data go black. This is a bug. I am trying to get out of there before it rains - my directions above could be slightly wrong. If so, let me know and I will correct them. | ||||||||
Project | Sandia | ||||||||
Topic Name | 14288_fix_lut_editor | ||||||||
(0031605) Utkarsh Ayachit (administrator) 2013-09-19 11:29 |
commit 68feaab3d1a7047b7a045e8a6f4bda52d11efe8b Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Thu Sep 19 11:27:39 2013 -0400 BUG 0014288. Fixed LUT editor issues. Due to incorrect order of setup methods, the vtkCompositeControlPointsItem instance we ending up synchronizing the control points on LUT and Opacity function. Fixed that. This was causing the bogus points to show up as reported in the bug report. Change-Id: I5bf2c92b20ea5e793b6896b3fef049c90281030f |
(0031607) Alan Scott (manager) 2013-09-19 21:00 |
Looks good. Tested on next, test again on master. |
(0031632) Utkarsh Ayachit (administrator) 2013-09-26 09:34 |
SUMMARY --------------------------------------------- Topics merged into master: 0014302_cth_adaptor_doesnt_work_in_4_x 14255_fix_translucent_rendering 14280_fix_multiview_rendering_in_batch 14282_fix_long_label 14288_fix_lut_editor 14290_fix_static_build_issues fix_baseline_thresholds (VTK) fix_control_points_editing fix_pqWidgets_on_windows fix_property_linking fix_pvpython_cmakescript fix-selection-test (VTK) parallel-surface-lic-pv pvweb-fix-vtk-documentation (VTK) update_vtk_master |
(0031643) Alan Scott (manager) 2013-09-26 17:19 |
Tested master, Linux, remote server. Nice fix. |
2013-09-18 21:47 | Alan Scott | New Issue | |
2013-09-19 09:00 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2013-09-19 11:29 | Utkarsh Ayachit | Topic Name | => 14288_fix_lut_editor |
2013-09-19 11:29 | Utkarsh Ayachit | Note Added: 0031605 | |
2013-09-19 11:29 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2013-09-19 11:29 | Utkarsh Ayachit | Fixed in Version | => git-next |
2013-09-19 11:29 | Utkarsh Ayachit | Resolution | open => fixed |
2013-09-19 21:00 | Alan Scott | Note Added: 0031607 | |
2013-09-26 09:29 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2013-09-26 09:34 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-09-26 09:34 | Utkarsh Ayachit | Note Added: 0031632 | |
2013-09-26 17:19 | Alan Scott | Note Added: 0031643 | |
2013-09-26 17:19 | Alan Scott | Status | customer review => closed |
2013-11-01 13:18 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
2015-01-11 08:23 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 96db9a32 |
2015-01-11 08:23 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 68feaab3 |
