0014282ParaView(No Category)public2013-09-17 12:592015-01-11 08:23
ReporterAlan Scott
Assigned ToUtkarsh Ayachit
StatusclosedResolutionfixed
PlatformOSOS Version
Product Versiongit-next
Target Version4.1Fixed in Version4.1
Summary0014282: CAM reader - Connectivity file name is too wide
DescriptionWith the CAM reader, the entry for the Connectivity file is too large, and doesn't scale to fit the Properties tab. You always have to miss with the left dialog box widths.
Master, Linux, remote server (local server will do).
Open Sandia-CAM-Data-Alan1-Do-Not-Release.nc (given to Utkarsh).
Choose the CAM NetCDF (Unstructured) reader. OK.
Now, browse to the Connectivity File. Note that the browse window is hidden. Either widen the properties tab dialog, or pull the horizontal ruler at the bottom of the dialog to the right.
Please make the width of the Connectivity File Name entry narrow enough to fit the default Properties panel width.
TagsNo tags attached.
ProjectSandia
Topic Name14282_fix_long_label
Typeincorrect functionality
 Relationships
  Notes
(0031606)
2013-09-19 11:43
commit 2919efd7b6e3df2f5c706175fbb9fdb24611ceb3
Date: Thu Sep 19 11:41:16 2013 -0400
    BUG 0014282. Fix long labels on Properties panel.
    Fixed size policy on label to ensure that the Properties panel doesn't end up
    requiring more horizintal space just because the label (that uses the proxy's
    name) is too long.
    Change-Id: If6ba4b976ed0f0ce685c0768640eb596a2cdbd1c
(0031608)
Alan Scott (manager)
2013-09-19 21:00
Looks good. tested on next, test again on master.
(0031631)
2013-09-26 09:34
SUMMARY
Topics merged into master:
        0014302_cth_adaptor_doesnt_work_in_4_x
        14255_fix_translucent_rendering
        14280_fix_multiview_rendering_in_batch
        14288_fix_lut_editor
        14290_fix_static_build_issues
        fix_baseline_thresholds
(VTK) fix_control_points_editing
        fix_pqWidgets_on_windows
        fix_property_linking
        fix_pvpython_cmakescript
        fix-selection-test
(VTK) parallel-surface-lic-pv
        pvweb-fix-vtk-documentation
(VTK) update_vtk_master
(0031646)
2013-09-26 17:25
Tested remote server, Linux, master.
 Issue History
2013-09-17 12:59 Alan Scott New Issue
2013-09-17 16:52 Utkarsh Ayachit Assigned To => Utkarsh Ayachit
2013-09-17 16:53 Utkarsh Ayachit Target Version => 4.1
2013-09-19 11:43 Utkarsh Ayachit Topic Name => 14282_fix_long_label
2013-09-19 11:43 Utkarsh Ayachit Note Added: 0031606
2013-09-19 11:43 Utkarsh Ayachit Status backlog => gatekeeper review
2013-09-19 11:43 Utkarsh Ayachit Fixed in Version => git-next
2013-09-19 11:43 Utkarsh Ayachit Resolution open => fixed
2013-09-19 21:00 Alan Scott Note Added: 0031608
2013-09-26 09:29 Utkarsh Ayachit Fixed in Version git-next => git-master
2013-09-26 09:34 Utkarsh Ayachit Status gatekeeper review => customer review
2013-09-26 09:34 Utkarsh Ayachit Note Added: 0031631
2013-09-26 17:25 Alan Scott Note Added: 0031646
2013-09-26 17:25 Alan Scott Status customer review => closed
2013-11-01 13:18 Utkarsh Ayachit Fixed in Version git-master => 4.1
2015-01-11 08:23 Utkarsh Ayachit Source_changeset_attached => ParaView master 2b897cd2
2015-01-11 08:23 Utkarsh Ayachit Source_changeset_attached => ParaView master 2919efd7
