0014280 | ParaView | (No Category) | public | 2013-09-17 10:17 | 2015-01-11 08:23 | ||||
Target Version | Fixed in Version | 4.1 | |||||||
Summary | 0014280: Multiple view rendering issues in batch/symmetric batch | ||||||||
Description | The attached script produces causes following issues: ----------------------------------------------------------------- > ./pvpython two_view.py This works as expected and produces 3 images of 2 views ----------------------------------------------------------------- > ./pvbatch two_view.py This doesn't render correctly. The chart view images are incorrect. They seem to simply show the result from the 3D render view. ----------------------------------------------------------------- > mpirun -np 2 ./pvbatch two_view.py OR > mpirun -np 2 ./pvbatch -sym two_view.py This dead locks on the first attempt to render the chart view. | ||||||||
Project | LANL-InSitu | ||||||||
Topic Name | 14280_fix_multiview_rendering_in_batch | ||||||||
Attached Files | two_view.py [^] (244 bytes) 2013-09-17 10:17 | ||||||||
(0031581) Utkarsh Ayachit (administrator) 2013-09-17 11:09 |
commit 64a18e67c15e6cab15de459519d595f47bbb3cca Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Tue Sep 17 11:06:04 2013 -0400 BUG 0014280: Fixed issues with multiple views in batch. Renderings with multiple views were ending up being mangled since the renderers were not getting disabled in the shared render window especially for chart views. This addresses that issue (added a test using the script provided by the bug report). Also fixed the warning message about StereoCapableRenderWindow that would pop up every time a new view was created in any mode where a shared render window was being used. Change-Id: I43a578c7978b45f452e6b6fd845aac764e0ef235 |
(0031630) Utkarsh Ayachit (administrator) 2013-09-26 09:34 |
SUMMARY --------------------------------------------- Topics merged into master: 0014302_cth_adaptor_doesnt_work_in_4_x 14255_fix_translucent_rendering 14280_fix_multiview_rendering_in_batch 14282_fix_long_label 14288_fix_lut_editor 14290_fix_static_build_issues fix_baseline_thresholds (VTK) fix_control_points_editing fix_pqWidgets_on_windows fix_property_linking fix_pvpython_cmakescript fix-selection-test (VTK) parallel-surface-lic-pv pvweb-fix-vtk-documentation (VTK) update_vtk_master |
(0032574) Alan Scott (manager) 2014-04-08 21:44 |
Tested local server, master, Linux. Used python script in this bug for testing. |
2013-09-17 10:17 | Utkarsh Ayachit | New Issue | |
2013-09-17 10:17 | Utkarsh Ayachit | File Added: two_view.py | |
2013-09-17 10:19 | Utkarsh Ayachit | Description Updated | |
2013-09-17 11:09 | Utkarsh Ayachit | Topic Name | => 14280_fix_multiview_rendering_in_batch |
2013-09-17 11:09 | Utkarsh Ayachit | Note Added: 0031581 | |
2013-09-17 11:09 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2013-09-17 11:09 | Utkarsh Ayachit | Fixed in Version | => git-next |
2013-09-17 11:09 | Utkarsh Ayachit | Resolution | open => fixed |
2013-09-17 11:09 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2013-09-26 09:29 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2013-09-26 09:34 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-09-26 09:34 | Utkarsh Ayachit | Note Added: 0031630 | |
2013-11-01 13:18 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
2014-04-08 21:44 | Alan Scott | Note Added: 0032574 | |
2014-04-08 21:44 | Alan Scott | Status | customer review => closed |
2015-01-11 08:23 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 1b402c18 |
2015-01-11 08:23 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 31689203 |
2015-01-11 08:23 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 64a18e67 |
