0014266 | VTK | (No Category) | public | 2013-09-06 15:38 | 2015-01-09 13:40 | ||||
Reporter | Clinton Stimpson | ||||||||
Assigned To | Sean McBride | ||||||||
Product Version | 6.1.0 | ||||||||
Target Version | 6.2.0 | Fixed in Version | 6.2.0 | ||||||
Summary | 0014266: Cocoa interactor reports wrong size | ||||||||
Description | Run the attached example. Resize the window, then hit the 'x' button to close the window. It'll print out the size reported by vtkRenderWindow and vtkRenderWindowInteractor. The interactor reports the wrong size, and its size is not updated when the window is resized. | ||||||||
Tags | hackaton | ||||||||
Project | TBD | ||||||||
Attached Files | cone.py [^] (772 bytes) 2013-09-06 15:38 | ||||||||
(0033434) Sean McBride (developer) 2014-10-02 10:21 |
OK, I can reproduce this. Will investigate... |
(0033509) Sean McBride (developer) 2014-10-02 14:34 |
Clinton, thanks for reporting this glaring bug. I only wished I noticed it months ago. I only found it searching for keywords like "Cocoa" before today's bug hack-a-thon. The cause of the bug is that we start observing for NSView size changes *before* we actually create the NSView. i.e. we observe nothing. Whoops. I probably broke this. Fix forthcoming... |
(0033541) Sean McBride (developer) 2014-10-02 16:29 |
http://review.source.kitware.com/17362 [^] |
2013-09-06 15:38 | Clinton Stimpson | New Issue | |
2013-09-06 15:38 | Clinton Stimpson | File Added: cone.py | |
2014-10-01 10:54 | Sean McBride | Assigned To | => Sean McBride |
2014-10-01 10:54 | Sean McBride | Status | backlog => tabled |
2014-10-01 10:55 | Sean McBride | Tag Attached: hackaton | |
2014-10-01 12:40 | Berk Geveci | Status | tabled => backlog |
2014-10-02 10:21 | Sean McBride | Note Added: 0033434 | |
2014-10-02 10:21 | Sean McBride | Target Version | => 6.2.0 |
2014-10-02 14:34 | Sean McBride | Note Added: 0033509 | |
2014-10-02 16:29 | Sean McBride | Note Added: 0033541 | |
2014-10-02 16:29 | Sean McBride | Status | backlog => gerrit review |
2014-10-02 16:29 | Sean McBride | Resolution | open => fixed |
2014-10-04 08:49 | David Gobbi | Status | gerrit review => closed |
2014-10-04 08:49 | David Gobbi | Fixed in Version | => 6.2.0 |
2015-01-09 13:33 | Sean McBride | Source_changeset_attached | => VTK master fca2fd59 |
2015-01-09 13:39 | Sean McBride | Source_changeset_attached | => VTK master 8bc22e48 |
2015-01-09 13:40 | Sean McBride | Source_changeset_attached | => VTK master b6a4db16 |
