0014260 | ParaView | (No Category) | public | 2013-09-05 12:04 | 2015-01-11 08:21 | ||||
Target Version | Fixed in Version | 4.1 | |||||||
Summary | 0014260: Settings/ Splash Screen is broken | ||||||||
Description | Linux, master, local server. delete your ~/.config/ParaView files. Alternatively, run paraview -dr in the next step. Run paraview. Notice that you see a splash screen. Edit/ Settings. Notice Disable Splash Screen is checked. This is incorrect. Uncheck Disable Splash screen. Exit, and restart ParaView. Notice there is a splash screen. This is correct. Check Disable Splash screen. Exit, and restart ParaView. Notice there is no splash screen. This is correct. | ||||||||
Project | Sandia | ||||||||
Topic Name | 14260_fix_splash_screen | ||||||||
(0031563) Utkarsh Ayachit (administrator) 2013-09-12 14:38 |
Alan, I could not reproduce this. You should not be seeing any splash screen when you run with "paraview -dr". That's exactly what I see. Utkarsh |
(0031570) Utkarsh Ayachit (administrator) 2013-09-16 11:58 |
SUMMARY --------------------------------------------- Topics merged into master: 14181_fix_link_camera 14274-fixup-catalyst 14275_fix_comparative_view 14276-hide-label-visibility (VTK) cosmotools-vtk-extensions (VTK) fix_segfault_on_invalid_input pvweb-state-loading |
(0031589) Alan Scott (manager) 2013-09-18 12:55 |
-dr does work correctly, but removing the .config files does not. Strange - no .config files acts differently than -dr. Anyway, reopening. (Utkarsh did so as we were working on an issue, but my note still applies.) |
(0031847) Utkarsh Ayachit (administrator) 2013-11-11 10:48 |
commit bf5094572c244a2671b0405ddbffb9477a62d6be Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Mon Nov 11 10:47:28 2013 -0500 BUG 0014260: Fixes splash screen default. Although splash screen is not expected to be show by default, we were ending up showing it. Fixed that. Change-Id: I6e9889243495ddb508b39d3864179d632a1763ab |
(0031861) Utkarsh Ayachit (administrator) 2013-11-17 11:36 |
Topics merged into master: (VTK) 14256-random-attribute-generator 14260_fix_splash_screen document-paraviewweb-on-aws-ec2 fix_particle_streaming (VTK) pvweb-group-file-in-visualizer (VTK) pvweb-proxy-file-listing (VTK) pvweb-py-launcher |
(0031972) Alan Scott (manager) 2013-12-16 21:57 |
I just tested, and could not replicate this bug. Marking closed. |
2013-09-05 12:04 | Alan Scott | New Issue | |
2013-09-12 14:38 | Utkarsh Ayachit | Note Added: 0031563 | |
2013-09-12 14:38 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2013-09-12 14:38 | Utkarsh Ayachit | Resolution | open => unable to reproduce |
2013-09-12 14:38 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2013-09-16 11:57 | Utkarsh Ayachit | Fixed in Version | => git-master |
2013-09-16 11:58 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-09-16 11:58 | Utkarsh Ayachit | Note Added: 0031570 | |
2013-09-18 12:53 | Utkarsh Ayachit | Status | customer review => backlog |
2013-09-18 12:53 | Utkarsh Ayachit | Resolution | unable to reproduce => reopened |
2013-09-18 12:55 | Alan Scott | Note Added: 0031589 | |
2013-11-01 13:18 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
2013-11-11 10:48 | Utkarsh Ayachit | Topic Name | => 14260_fix_splash_screen |
2013-11-11 10:48 | Utkarsh Ayachit | Note Added: 0031847 | |
2013-11-11 10:48 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2013-11-11 10:48 | Utkarsh Ayachit | Fixed in Version | 4.1 => git-next |
2013-11-11 10:48 | Utkarsh Ayachit | Resolution | reopened => fixed |
2013-11-17 11:36 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2013-11-17 11:36 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-11-17 11:36 | Utkarsh Ayachit | Note Added: 0031861 | |
2013-12-16 21:57 | Alan Scott | Note Added: 0031972 | |
2013-12-16 21:57 | Alan Scott | Status | customer review => closed |
2014-01-11 08:39 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
2015-01-11 08:21 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 37dd8e65 |
2015-01-11 08:21 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master bf509457 |
