0014256 | ParaView | (No Category) | public | 2013-08-29 12:46 | 2014-01-11 08:39 | ||||
Assigned To | Dan Lipsa | ||||||||
Target Version | 4.1 | Fixed in Version | 4.1 | ||||||
Summary | 0014256: Random color filter | ||||||||
Description | We need a filter that will paint cells by random colors. This is different than the new catigorical color code. An example would be to paint disk_out_ref.exo by GlobalElementId. For this bug, lets make the filter dumb. In other words, don't worry about cells that end up the same color next to each other (that are not in contiguous GlobalElementId order). An example of what I want is shown by creating a random number in the calculator. It is part of my tutorials here: http://www.paraview.org/Wiki/Beginning_Filters#Calculator_filter [^] | ||||||||
Project | Sandia | ||||||||
Topic Name | 14256-random-attribute-generator | ||||||||
Relationships | ||||||
(0031857) Dan Lipsa (developer) 2013-11-15 09:02 |
VTK commits: commit 5bad3ea57e393f7ec62e7a08565d2756eb763efc Author: Dan Lipsa <dan.lipsa@kitware.com> Date: Mon Nov 11 16:21:43 2013 -0500 RandomAttributeGenerator can generate attributes constant within a block Added a test for this feature as as well. Change-Id: I8d56c324c51c19f5f795a92e5074b13f1b58af4b commit 995272cc28f0f84cdcfdce99ed45a0ac30fce1d8 Author: Dan Lipsa <dan.lipsa@kitware.com> Date: Thu Nov 7 17:09:53 2013 -0500 RandomAttributeGenerator names its generated attribute arrays Also, clean-up the tests for RandomAttributeGenerator and BrownianPoints and added a 'see also' section for the two classes. Change-Id: Ia9886c91743c80ce92cae8176b55d43553d4dcf3 Paraview commits: commit 0245f2c03dd6951287d9ccd20a72a607759e9462 Author: Dan Lipsa <dan.lipsa@kitware.com> Date: Mon Nov 11 16:24:47 2013 -0500 Add an extra parameter to Random Attributes filter. Extra parameter allows for attributes constant within a block. Change-Id: I6f2a547fe9fc9154844db5d91f8fa235ca16d540 commit 11b2d67f9c1b925a8393c5d82a402258e5c9dd07 Author: Dan Lipsa <dan.lipsa@kitware.com> Date: Thu Nov 7 17:15:39 2013 -0500 Make RandomAttributeFilter visible in Paraview and add a test for it. Change-Id: I80aa6286631cb7554f97d8a5ce2d2728c848cdde |
(0031860) Utkarsh Ayachit (administrator) 2013-11-17 11:36 |
Topics merged into master: (VTK) 14256-random-attribute-generator 14260_fix_splash_screen document-paraviewweb-on-aws-ec2 fix_particle_streaming (VTK) pvweb-group-file-in-visualizer (VTK) pvweb-proxy-file-listing (VTK) pvweb-py-launcher |
(0031971) Alan Scott (manager) 2013-12-16 21:54 |
Nice! Tested remote server, Linux, master. |
2013-08-29 12:46 | Alan Scott | New Issue | |
2013-08-29 21:20 | Utkarsh Ayachit | Target Version | => 4.1 |
2013-10-29 11:09 | Utkarsh Ayachit | Assigned To | => Dan Lipsa |
2013-11-04 15:12 | Dan Lipsa | Status | backlog => active development |
2013-11-13 14:45 | Dan Lipsa | Topic Name | => 14256-random-attribute-generator |
2013-11-15 09:02 | Dan Lipsa | Note Added: 0031857 | |
2013-11-15 09:02 | Dan Lipsa | Status | active development => gatekeeper review |
2013-11-17 11:36 | Utkarsh Ayachit | Fixed in Version | => git-master |
2013-11-17 11:36 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-11-17 11:36 | Utkarsh Ayachit | Note Added: 0031860 | |
2013-12-16 21:54 | Alan Scott | Note Added: 0031971 | |
2013-12-16 21:54 | Alan Scott | Status | customer review => closed |
2013-12-16 21:54 | Alan Scott | Resolution | open => fixed |
2014-01-11 08:39 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
2014-02-13 14:31 | Utkarsh Ayachit | Relationship added | related to 0011856 |
