0014253 | ParaView | (No Category) | public | 2013-08-28 22:16 | 2015-01-11 08:23 | ||||
Target Version | 4.1 | Fixed in Version | 4.1 | ||||||
Summary | 0014253: Opacity is problematic | ||||||||
Description | Linux, remote server, master. Sources/ Mandlebrot. Apply. 3D. Sources/ Plane. Apply. Highlight Mandlebrot. Change Opacity to 0.99. Everything goes away. This is standing in the way of a very important viz, along with my debugging a crash. Thus, marking as high priority. | ||||||||
Project | Sandia | ||||||||
Topic Name | 14253_fix_translucent_slices | ||||||||
Relationships | ||||||
(0031501) Alan Scott (manager) 2013-08-28 22:24 |
Not sure if this is the same bug - I believe it is. Thus, here is another way to get to the same bug: Linux, remote server, master. Sources/ Mandlebrot. Apply. 3D. Sources/ Plane. Apply. Highlight Mandlebrot. Color Editor. Enable opacity mapping for surfaces. Update. Everything goes away. |
(0031503) Utkarsh Ayachit (administrator) 2013-08-29 09:33 edited on: 2013-08-29 09:37 |
The problem is with Slice representation. The view doesn't switch into the mode where it uses ordered compositing. Same is the problem when making LUT use translucency. |
(0031504) Utkarsh Ayachit (administrator) 2013-08-29 11:45 |
commit bd5179583572be4fd3315d0dce0b98b00cf90297 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Thu Aug 29 10:18:52 2013 -0400 BUG 0014253. Fix translucent slice representations rendering. When rendering image-slices with translucency, vtkImageSliceRepresentation was not telling the view to use ordered compositing. That was causing the rendering to fail as manifested by the bug 0014253. This fixes that issue. vtkImageSliceRepresentation now correctly requests ordered compositing when needed. Also fixed a bug in vtkOrderedCompositeDistributor which resulted in the filter crashing when a process ended up with an empty dataset after redistribution for ordered compositing. We just needed to check if the data has valid points before we attempted to extract the exterior surface from it. Change-Id: I2b1483e98c8a9c95be9e3076252badc6217cf0ab |
(0031505) Utkarsh Ayachit (administrator) 2013-08-29 11:51 |
Added a new bug 0014255 for the "Enable opacity mapping" issue, which is unrelated. |
(0031514) Utkarsh Ayachit (administrator) 2013-09-03 11:11 |
SUMMARY --------------------------------------------- Topics merged into master: 14245_fix_default_values 14253_fix_translucent_slices 14257-gl2ps-dialog fix_edit_control_points (VTK) fix_plot3d_issue fix_vtk_mpi_change |
(0031519) Alan Scott (manager) 2013-09-03 19:02 |
Tested remote server, Master, Linux. |
2013-08-28 22:16 | Alan Scott | New Issue | |
2013-08-28 22:24 | Alan Scott | Note Added: 0031501 | |
2013-08-29 09:26 | Utkarsh Ayachit | Target Version | => 4.1 |
2013-08-29 09:33 | Utkarsh Ayachit | Note Added: 0031503 | |
2013-08-29 09:37 | Utkarsh Ayachit | Note Edited: 0031503 | |
2013-08-29 11:45 | Utkarsh Ayachit | Topic Name | => 14253_fix_translucent_slices |
2013-08-29 11:45 | Utkarsh Ayachit | Note Added: 0031504 | |
2013-08-29 11:45 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2013-08-29 11:45 | Utkarsh Ayachit | Fixed in Version | => git-next |
2013-08-29 11:45 | Utkarsh Ayachit | Resolution | open => fixed |
2013-08-29 11:45 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2013-08-29 11:50 | Utkarsh Ayachit | Relationship added | related to 0014255 |
2013-08-29 11:51 | Utkarsh Ayachit | Note Added: 0031505 | |
2013-09-03 11:10 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2013-09-03 11:11 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-09-03 11:11 | Utkarsh Ayachit | Note Added: 0031514 | |
2013-09-03 19:02 | Alan Scott | Note Added: 0031519 | |
2013-09-03 19:02 | Alan Scott | Status | customer review => closed |
2013-11-01 13:18 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
2015-01-11 08:23 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master be8dc6d1 |
2015-01-11 08:23 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master bd517958 |
