0014226 | ParaView | (No Category) | public | 2013-08-13 18:22 | 2015-01-11 08:23 | ||||
Product Version | 4.0 | ||||||||
Target Version | 4.1 | Fixed in Version | 4.1 | ||||||
Summary | 0014226: Line Chart Interaction: Find Data dialog breaks selection in line chart view | ||||||||
Description | I discovered by accident that if you try to create a selection with the Find Data dialog box on data viewed in a line chart view, the interactive selection in the line chart view ceases to work. To replicate, do the following. 1. Create a Worklet source. Apply. 2. Plot Over Line. Apply. 3. In the line chart view, attempt an interactive selection. It should work fine. 4. Open the Find Data dialog box. 5. For points from the Plot Over Line filter, search for ID is 10 and press Run Selection Query. (Should work fine.) 6. Close the Find Data dialog and try to interactively select points in the line chart view. It no longer works. | ||||||||
Project | Sandia | ||||||||
Topic Name | fix_chart_interactions | ||||||||
(0031806) Utkarsh Ayachit (administrator) 2013-10-31 12:44 |
commit f8113ee4f4d206396c5d992da1baf4d9ec2979ae Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Thu Oct 31 12:42:33 2013 -0400 BUG 0014226: Fix selection on charts + find data Making pqContextView use the vtkSMSelectionHelper to create new selection proxy instead of the custom code. The custom code was not working correctly when the current selection source was not of the expected type. vtkSMSelectionHelper handles all those cases. Also removing obsolete code pqSelectionManager for creating selection sources. Use vtkSMSelectionHelper instead. Change-Id: Ia994af7cf04f2f9f97b202b10b6a617b96f2af83 |
(0031816) Utkarsh Ayachit (administrator) 2013-11-01 13:11 |
SUMMARY --------------------------------------------- Topics merged into master: selection_enhancements pvweb-fix-script-path fix_chart_interactions 14376_fix_settings_dialog 14375-in-situ 14371_fix_color_function_rescale 14287_fix_time_and_find_data --------------------------------------------- Topics reverted from next: paraview-web-client-tests vtkweb-url-arg-parsing *NOTE* these topics were reverted since the referenced VTK topics were not merged in VTK master |
(0031828) Ken Moreland (manager) 2013-11-04 13:46 |
Neat. I really like how Find Data interacts with the plot now. I can see queries in the plot and can modify plot selections with Find Data. |
2013-08-13 18:22 | Ken Moreland | New Issue | |
2013-09-03 12:44 | Utkarsh Ayachit | Assigned To | => Kyle Lutz |
2013-09-04 11:13 | Kyle Lutz | Status | backlog => active development |
2013-10-31 11:17 | Utkarsh Ayachit | Assigned To | Kyle Lutz => Utkarsh Ayachit |
2013-10-31 11:18 | Utkarsh Ayachit | Target Version | => 4.1 |
2013-10-31 11:18 | Utkarsh Ayachit | Status | active development => todo |
2013-10-31 12:44 | Utkarsh Ayachit | Topic Name | => fix_chart_interactions |
2013-10-31 12:44 | Utkarsh Ayachit | Note Added: 0031806 | |
2013-10-31 12:44 | Utkarsh Ayachit | Status | todo => gatekeeper review |
2013-10-31 12:44 | Utkarsh Ayachit | Fixed in Version | => git-next |
2013-10-31 12:44 | Utkarsh Ayachit | Resolution | open => fixed |
2013-11-01 13:11 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2013-11-01 13:11 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-11-01 13:11 | Utkarsh Ayachit | Note Added: 0031816 | |
2013-11-01 13:17 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
2013-11-04 13:46 | Ken Moreland | Note Added: 0031828 | |
2013-11-04 13:46 | Ken Moreland | Status | customer review => closed |
2015-01-11 08:23 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 4a50e48a |
2015-01-11 08:23 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master f8113ee4 |
