0014223 | ParaView | (No Category) | public | 2013-08-13 17:52 | 2015-01-11 08:23 | ||||
Assigned To | |||||||||
Product Version | 4.0 | ||||||||
Target Version | 4.1 | Fixed in Version | 4.1 | ||||||
Summary | 0014223: Line Chart Interaction: Left button pan stops working | ||||||||
Description | There are a whole lot of things wrong with the interaction in line charts, which is going to be embarrassing when they are brought up in the ParaView tutorial. I have discovered that if you use one of the selection buttons and then turn it back off, then panning no longer works in the line chart view. To replicate, do the following: 1. Create a Wavelet source. Apply. 2. Plot Over Line. Apply. 3. Drag the left button in the line chart view. It pans correctly. 4. Click one of the selection buttons (such as the Add Selection button). 5. Select something. 6. Click off that selection button. At this point the line chart should go back to panning with the left button, but it does nothing. There is no longer any way to pan. | ||||||||
Project | Sandia | ||||||||
Topic Name | fix_chart_interactions | ||||||||
(0031782) Utkarsh Ayachit (administrator) 2013-10-30 14:37 |
commit d09ef6282db175c1e0fe11296b24119bdd6354d7 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Wed Oct 30 14:31:33 2013 -0400 Fixes issue with selections in charts. This addresses several bugs with chart interactions and selections including BUG 0014223, BUG 0014224, BUG 0014225. We now have two buttons for selection types: rectangular and polygonal. One presses those to enter selection mode (or use the corresponding key-board shortcuts). The modifier buttons are don't start/stop selection, but just affect how the selection is updated on the subsequent selection action. Selection modifier is persistent and hence persists till user manually changes it. We switch in and out of selection mode similar to what we do for 3D view i.e. on mouse-up, we come out selection mode to regular interaction mode. Change-Id: I0e1c683921f2a7c777ab28d62def4157233b180f |
(0031819) Utkarsh Ayachit (administrator) 2013-11-01 13:11 |
SUMMARY --------------------------------------------- Topics merged into master: selection_enhancements pvweb-fix-script-path fix_chart_interactions 14376_fix_settings_dialog 14375-in-situ 14371_fix_color_function_rescale 14287_fix_time_and_find_data --------------------------------------------- Topics reverted from next: paraview-web-client-tests vtkweb-url-arg-parsing *NOTE* these topics were reverted since the referenced VTK topics were not merged in VTK master |
2013-08-13 17:52 | Ken Moreland | New Issue | |
2013-08-13 17:53 | Ken Moreland | Target Version | => 4.1 |
2013-09-16 11:35 | Utkarsh Ayachit | Assigned To | => Kyle Lutz |
2013-10-30 14:37 | Utkarsh Ayachit | Topic Name | => fix_chart_interactions |
2013-10-30 14:37 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2013-10-30 14:37 | Utkarsh Ayachit | Note Added: 0031782 | |
2013-11-01 13:11 | Utkarsh Ayachit | Fixed in Version | => git-master |
2013-11-01 13:11 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-11-01 13:11 | Utkarsh Ayachit | Note Added: 0031819 | |
2013-11-01 13:17 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
2013-11-04 13:42 | Ken Moreland | Status | customer review => closed |
2013-11-04 13:42 | Ken Moreland | Assigned To | Kyle Lutz => |
2013-11-04 13:42 | Ken Moreland | Resolution | open => fixed |
2015-01-11 08:23 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master d09ef628 |
