0014219 | ParaView | (No Category) | public | 2013-08-12 11:17 | 2013-11-01 13:18 | ||||
Reporter | Sebastien Jourdain | ||||||||
Assigned To | Sebastien Jourdain | ||||||||
Target Version | Fixed in Version | 4.1 | |||||||
Summary | 0014219: External plugins works only with parent plugin directory on Windows | ||||||||
Description | PARAVIEW_EXTERNAL_PLUGIN_DIRS expect a directory that contains ParaView plugins, but it is nice to also have a way to provide only one external plugin and properly support it. This has been fixed in the following commit: stage/fix_cmake_external_plugin_macro commit b817d6cd1aa01709762ccf3e769d49f034d6b8e6 Author: Sebastien Jourdain <sebastien.jourdain@kitware.com> Date: Mon Aug 12 11:11:45 2013 -0400 Fix PARAVIEW_EXTERNAL_PLUGIN_DIRS CMake Macro Allow PARAVIEW_EXTERNAL_PLUGIN_DIRS to be the Plugin directory and not only its parent. It use to work fine on Unix system as the double / was properly ingored but on Windows it will simply failed. Change-Id: Ia14830b3e2ed7f253e6b1a01977be4017b85a443 diff --git a/CMake/ParaViewPluginsMacros.cmake b/CMake/ParaViewPluginsMacros.cmake index 5b0a1cd..f8549f1 100644 --- a/CMake/ParaViewPluginsMacros.cmake +++ b/CMake/ParaViewPluginsMacros.cmake @@ -136,7 +136,12 @@ macro(pv_plugin_search_under_root root_src root_build) file(GLOB_RECURSE files RELATIVE "${root_src}" "${root_src}/plugin.cmake") foreach(plugin_file IN LISTS files) get_filename_component(base "${plugin_file}" PATH) - pv_add_plugin("${root_src}/${base}" plugin.cmake "${root_build}/${base}") + if(base) + pv_add_plugin("${root_src}/${base}" plugin.cmake "${root_build}/${base}") + else() + # The root directory is in fact the plugin directory + pv_add_plugin("${root_src}" plugin.cmake "${root_build}") + endif() endforeach() endmacro() | ||||||||
Project | TBD | ||||||||
Topic Name | fix_cmake_external_plugin_macro | ||||||||
(0031480) Utkarsh Ayachit (administrator) 2013-08-16 13:48 |
Topics merged into master: 0014218_fix_color_preset_issues 13029_fix_auto_apply 14158_fix_double_range_slider 14185_fix_component_name 14204_fix_domains 14233_fix_disconnect_button 14234_fix_trace_views better_disconnect_error_v2 serverside_only_reader (VTK) update_to_master |
(0031600) Alan Scott (manager) 2013-09-18 14:32 |
I don't know how to test, will depend on Seb's testing. |
2013-08-12 11:17 | Sebastien Jourdain | New Issue | |
2013-08-12 11:17 | Sebastien Jourdain | Assigned To | => Sebastien Jourdain |
2013-08-12 11:18 | Sebastien Jourdain | Topic Name | => fix_cmake_external_plugin_macro |
2013-08-12 11:18 | Sebastien Jourdain | Status | backlog => gatekeeper review |
2013-08-12 11:18 | Sebastien Jourdain | Resolution | open => fixed |
2013-08-16 13:48 | Utkarsh Ayachit | Fixed in Version | => git-master |
2013-08-16 13:48 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-08-16 13:48 | Utkarsh Ayachit | Note Added: 0031480 | |
2013-09-18 14:32 | Alan Scott | Note Added: 0031600 | |
2013-09-18 14:32 | Alan Scott | Status | customer review => closed |
2013-11-01 13:18 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
