0014218 | ParaView | (No Category) | public | 2013-08-09 19:30 | 2015-01-11 08:24 | ||||
Target Version | 4.1 | Fixed in Version | 4.1 | ||||||
Summary | 0014218: Presets not working correctly | ||||||||
Description | Marking as high, since this has to do with the color editor, and that is just being finished up. * Master, Linux, Remote server (I am sure it will happen local server). * Wavelet. Surface. RTData. * Color editor. Choose Preset. Choose Grayscale. Close. Update. <This works> * Color editor. Choose Preset. <Notice that Cool to Warm is already highlighted.> Choose Cool to Warm. Mapping Data never changes from Greyscale. * Close. Update. Nothing changes. Workaround (that may show what is going on - select Blue to Red Rainbow, then again Cool to Warm. Close, Update. This works. | ||||||||
Project | Sandia | ||||||||
Topic Name | 0014218_fix_color_preset_issues | ||||||||
Relationships | ||||||
(0031469) Utkarsh Ayachit (administrator) 2013-08-15 16:39 |
commit 62c9bbd5900a9b7d85c89d74607703484f039302 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Thu Aug 15 16:37:21 2013 -0400 BUG 0014218. Fixes color preset issues. The color preset dialog showed up with the first item active. As a result when the user clicked on it, it wouldn't realize that the user selected and it and hence would never change to that item causing the reported bug. We fix it by using the selection-changed signal rather than the current-changed to catch this case. Change-Id: I1e99fc25cfc8095bef80afdf888dcf36b7d6b846 |
(0031471) Utkarsh Ayachit (administrator) 2013-08-16 13:48 |
Topics merged into master: 0014218_fix_color_preset_issues 13029_fix_auto_apply 14158_fix_double_range_slider 14185_fix_component_name 14204_fix_domains 14233_fix_disconnect_button 14234_fix_trace_views better_disconnect_error_v2 serverside_only_reader (VTK) update_to_master |
(0031530) Alan Scott (manager) 2013-09-03 21:12 |
Tested Linux, master, remote server. |
2013-08-09 19:30 | Alan Scott | New Issue | |
2013-08-09 19:30 | Alan Scott | Assigned To | => Utkarsh Ayachit |
2013-08-15 15:32 | Utkarsh Ayachit | Target Version | => 4.1 |
2013-08-15 16:39 | Utkarsh Ayachit | Topic Name | => 0014218_fix_color_preset_issues |
2013-08-15 16:39 | Utkarsh Ayachit | Note Added: 0031469 | |
2013-08-15 16:39 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2013-08-15 16:39 | Utkarsh Ayachit | Fixed in Version | => git-next |
2013-08-15 16:39 | Utkarsh Ayachit | Resolution | open => fixed |
2013-08-16 13:48 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2013-08-16 13:48 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-08-16 13:48 | Utkarsh Ayachit | Note Added: 0031471 | |
2013-08-30 13:50 | Utkarsh Ayachit | Relationship added | has duplicate 0014249 |
2013-09-03 21:12 | Alan Scott | Note Added: 0031530 | |
2013-09-03 21:12 | Alan Scott | Status | customer review => closed |
2013-11-01 13:18 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
2015-01-11 08:24 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 06fe35e2 |
2015-01-11 08:24 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 62c9bbd5 |
