Attached Files | foo.py [^] (147 bytes) 2013-08-06 11:46
0001-BUG-14221.-Avoid-unnecessary-gather-with-TextSourceR.patch [^] (13,081 bytes) 2013-08-06 11:51 [Show Content] [Hide Content]From 8ac5e3074e0180a05480540cb2ba205c88e822ae Mon Sep 17 00:00:00 2001
From: Utkarsh Ayachit <utkarsh.ayachit@kitware.com>
Date: Tue, 6 Aug 2013 11:47:26 -0400
Subject: [PATCH] BUG #14221. Avoid unnecessary gather with
TextSourceRepresentation.
vtkTextSourceRepresentation was unnecessary doing a data-clone (despite the fact
that all data-server nodes have valid data). This added unnecessary
communication between all processes and hence was causing a performance
degradation as experienced by BUG #14221 (and other Catalyst users). Fixed that.
vtkTextSourceRepresentation still needs data delivered to client always (since
the 2D renderer is not composited), but we ensure that we no longer to any
gathers/scatters thus avoiding parallel communication.
Change-Id: I98a85ef4b911f813533ab7ed7c0ee4cee2adbca1
.../ClientServerCore/Rendering/vtkMPIMoveData.cxx | 12 ++++++
.../ClientServerCore/Rendering/vtkMPIMoveData.h | 11 ++++-
.../Rendering/vtkPVDataDeliveryManager.cxx | 45 +++++++++++++++++---
.../Rendering/vtkPVDataDeliveryManager.h | 13 ++++++
.../ClientServerCore/Rendering/vtkPVRenderView.cxx | 8 ++--
.../ClientServerCore/Rendering/vtkPVRenderView.h | 23 ++++++++--
.../Rendering/vtkTextSourceRepresentation.cxx | 3 +-
7 files changed, 101 insertions(+), 14 deletions(-)
diff --git a/ParaViewCore/ClientServerCore/Rendering/vtkMPIMoveData.cxx b/ParaViewCore/ClientServerCore/Rendering/vtkMPIMoveData.cxx
index d7b53fa..f988a4a 100644
--- a/ParaViewCore/ClientServerCore/Rendering/vtkMPIMoveData.cxx
+++ b/ParaViewCore/ClientServerCore/Rendering/vtkMPIMoveData.cxx
@@ -103,6 +103,8 @@ vtkMPIMoveData::vtkMPIMoveData()
this->UpdateNumberOfPieces = 0;
this->UpdatePiece = 0;
+ this->SkipDataServerGatherToZero = false;
@@ -699,6 +701,14 @@ void vtkMPIMoveData::DataServerGatherToZero(vtkDataObject* input,
return;
+ if (this->SkipDataServerGatherToZero)
+ if (this->Controller->GetLocalProcessId() == 0 && input)
+ output->ShallowCopy(input);
+ return;
vtkTimerLog::MarkStartEvent("Dataserver gathering to 0");
@@ -1210,6 +1220,8 @@ void vtkMPIMoveData::PrintSelf(ostream& os, vtkIndent indent)
os << indent << "NumberOfBuffers: " << this->NumberOfBuffers << endl;
os << indent << "Server: " << this->Server << endl;
os << indent << "MoveMode: " << this->MoveMode << endl;
+ os << indent << "SkipDataServerGatherToZero: " <<
+ this->SkipDataServerGatherToZero << endl;
os << indent << "OutputDataType: ";
if (this->OutputDataType == VTK_POLY_DATA)
diff --git a/ParaViewCore/ClientServerCore/Rendering/vtkMPIMoveData.h b/ParaViewCore/ClientServerCore/Rendering/vtkMPIMoveData.h
index d87a6ea..064e940 100644
--- a/ParaViewCore/ClientServerCore/Rendering/vtkMPIMoveData.h
+++ b/ParaViewCore/ClientServerCore/Rendering/vtkMPIMoveData.h
@@ -76,7 +76,8 @@ public:
void SetMoveModeToPassThrough(){this->MoveMode=vtkMPIMoveData::PASS_THROUGH;}
void SetMoveModeToCollect(){this->MoveMode=vtkMPIMoveData::COLLECT;}
void SetMoveModeToClone(){this->MoveMode=vtkMPIMoveData::CLONE;}
- vtkSetClampMacro(MoveMode, int, vtkMPIMoveData::PASS_THROUGH, vtkMPIMoveData::CLONE);
+ vtkSetClampMacro(MoveMode, int, vtkMPIMoveData::PASS_THROUGH,
+ vtkMPIMoveData::COLLECT_AND_PASS_THROUGH);
// Description:
// Controls the output type. This is required because processes receiving
@@ -102,6 +103,13 @@ public:
// successful Update() given the current ivars).
bool GetOutputGeneratedOnProcess();
+ // Description:
+ // When set, vtkMPIMoveData will skip the gather-to-root-node process
+ // altogether. This is useful when the data is already cloned on the
+ // server-nodes or we are interested in the root-node result alone.
+ vtkSetMacro(SkipDataServerGatherToZero, bool);
+ vtkGetMacro(SkipDataServerGatherToZero, bool);
//BTX
enum MoveModes {
PASS_THROUGH=0,
@@ -155,6 +163,7 @@ protected:
int MoveMode;
int Server;
+ bool SkipDataServerGatherToZero;
//BTX
enum Servers {
CLIENT=0,
diff --git a/ParaViewCore/ClientServerCore/Rendering/vtkPVDataDeliveryManager.cxx b/ParaViewCore/ClientServerCore/Rendering/vtkPVDataDeliveryManager.cxx
index 9295c34..37d4deb 100644
--- a/ParaViewCore/ClientServerCore/Rendering/vtkPVDataDeliveryManager.cxx
+++ b/ParaViewCore/ClientServerCore/Rendering/vtkPVDataDeliveryManager.cxx
@@ -99,7 +99,9 @@ public:
vtkOrderedCompositingInfo OrderedCompositingInfo;
vtkWeakPointer<vtkPVDataRepresentation> Representation;
- bool AlwaysClone;
+ bool CloneDataToAllNodes;
+ bool DeliverToClientAndRenderingProcesses;
+ bool GatherBeforeDeliveringToClient;
bool Redistributable;
bool Streamable;
@@ -107,7 +109,9 @@ public:
Producer(vtkSmartPointer<vtkPVTrivialProducer>::New()),
TimeStamp(0),
ActualMemorySize(0),
- AlwaysClone(false),
+ CloneDataToAllNodes(false),
+ DeliverToClientAndRenderingProcesses(false),
+ GatherBeforeDeliveringToClient(false),
Redistributable(false),
Streamable(false)
@@ -287,7 +291,24 @@ void vtkPVDataDeliveryManager::SetDeliverToAllProcesses(
vtkInternals::vtkItem* item = this->Internals->GetItem(repr, low_res);
if (item)
- item->AlwaysClone = mode;
+ item->CloneDataToAllNodes = mode;
+ else
+ vtkErrorMacro("Invalid argument.");
+void vtkPVDataDeliveryManager::SetDeliverToClientAndRenderingProcesses(
+ vtkPVDataRepresentation* repr, bool deliver_to_client,
+ bool gather_before_delivery, bool low_res)
+ vtkInternals::vtkItem* item = this->Internals->GetItem(repr, low_res);
+ if (item)
+ item->DeliverToClientAndRenderingProcesses = deliver_to_client;
+ item->GatherBeforeDeliveringToClient = gather_before_delivery;
else
@@ -484,10 +505,24 @@ void vtkPVDataDeliveryManager::Deliver(int use_lod, unsigned int size, unsigned
dataMover->InitializeForCommunicationForParaView();
dataMover->SetOutputDataType(data->GetDataObjectType());
dataMover->SetMoveMode(mode);
- if (item->AlwaysClone)
+ if (item->CloneDataToAllNodes)
dataMover->SetMoveModeToClone();
+ else if (item->DeliverToClientAndRenderingProcesses)
+ if (mode == vtkMPIMoveData::PASS_THROUGH)
+ dataMover->SetMoveMode(vtkMPIMoveData::COLLECT_AND_PASS_THROUGH);
+ else
+ // nothing to do, since the data is going to be delivered to the client
+ // anyways.
+ dataMover->SetSkipDataServerGatherToZero(
+ item->GatherBeforeDeliveringToClient == false);
dataMover->SetInputData(data);
if (dataMover->GetOutputGeneratedOnProcess())
@@ -695,7 +730,7 @@ void vtkPVDataDeliveryManager::DeliverStreamedPieces(
diff --git a/ParaViewCore/ClientServerCore/Rendering/vtkPVDataDeliveryManager.h b/ParaViewCore/ClientServerCore/Rendering/vtkPVDataDeliveryManager.h
index 9acdea8..2dba572 100644
--- a/ParaViewCore/ClientServerCore/Rendering/vtkPVDataDeliveryManager.h
+++ b/ParaViewCore/ClientServerCore/Rendering/vtkPVDataDeliveryManager.h
@@ -86,6 +86,19 @@ public:
void SetDeliverToAllProcesses(vtkPVDataRepresentation*, bool flag, bool low_res);
// Description:
+ // By default, this class only delivers geometries to nodes that are doing the
+ // rendering at a given stage. However, certain representations, such as
+ // text-source representation, need to the geometry to be delivered to the
+ // client as well. That can be done by using this method (via
+ // vtkPVRenderView::SetDeliverToAllProcesses()). The different between
+ // SetDeliverToAllProcesses() and this is that the former gather-and-scatters
+ // the data on the server nodes, while the latter will optionally gather the data to
+ // deliver to the client and never scatter.
+ void SetDeliverToClientAndRenderingProcesses(
+ vtkPVDataRepresentation*, bool deliver_to_client,
+ bool gather_before_delivery, bool low_res);
+ // Description:
// Under certain cases, e.g. when remote rendering in parallel with
// translucent geometry, the geometry may need to be redistributed to ensure
// ordered compositing can be employed correctly. Marking geometry provided by
diff --git a/ParaViewCore/ClientServerCore/Rendering/vtkPVRenderView.cxx b/ParaViewCore/ClientServerCore/Rendering/vtkPVRenderView.cxx
index 7159e04..6ecb4bc 100644
--- a/ParaViewCore/ClientServerCore/Rendering/vtkPVRenderView.cxx
+++ b/ParaViewCore/ClientServerCore/Rendering/vtkPVRenderView.cxx
@@ -1306,8 +1306,9 @@ void vtkPVRenderView::SetDeliverToAllProcesses(vtkInformation* info,
-void vtkPVRenderView::SetDeliverLODToAllProcesses(vtkInformation* info,
- vtkPVDataRepresentation* repr, bool clone)
+void vtkPVRenderView::SetDeliverToClientAndRenderingProcesses(
+ vtkInformation* info, vtkPVDataRepresentation* repr,
+ bool deliver_to_client, bool gather_before_delivery)
vtkPVRenderView* view = vtkPVRenderView::SafeDownCast(info->Get(VIEW()));
if (!view)
@@ -1316,7 +1317,8 @@ void vtkPVRenderView::SetDeliverLODToAllProcesses(vtkInformation* info,
return;
- view->GetDeliveryManager()->SetDeliverToAllProcesses(repr, clone, true);
+ view->GetDeliveryManager()->SetDeliverToClientAndRenderingProcesses(
+ repr, deliver_to_client, gather_before_delivery, false);
diff --git a/ParaViewCore/ClientServerCore/Rendering/vtkPVRenderView.h b/ParaViewCore/ClientServerCore/Rendering/vtkPVRenderView.h
index 3e6a337..c337cda 100644
--- a/ParaViewCore/ClientServerCore/Rendering/vtkPVRenderView.h
+++ b/ParaViewCore/ClientServerCore/Rendering/vtkPVRenderView.h
@@ -324,10 +324,6 @@ public:
vtkPVDataRepresentation* repr, vtkDataObject* data);
static vtkAlgorithmOutput* GetPieceProducerLOD(vtkInformation* info,
vtkPVDataRepresentation* repr);
- static void SetDeliverToAllProcesses(
- vtkInformation* info, vtkPVDataRepresentation* repr, bool clone);
- static void SetDeliverLODToAllProcesses(
static void MarkAsRedistributable(
vtkInformation* info, vtkPVDataRepresentation* repr);
static void SetGeometryBounds(vtkInformation* info,
@@ -340,6 +336,25 @@ public:
// Description:
+ // Requests the view to deliver the pieces produced by the \c repr to all
+ // processes after a gather to the root node to merge the datasets generated
+ // by each process.
+ static void SetDeliverToAllProcesses(
+ vtkInformation* info, vtkPVDataRepresentation* repr, bool clone);
+ // Description:
+ // Requests the view to deliver the data to the client always. This is
+ // essential for representation that render in the non-composited views e.g.
+ // the text-source representation. If SetDeliverToAllProcesses() is true, this
+ // is redundant. \c gather_before_delivery can be used to indicate if the data
+ // on the server-nodes must be gathered to the root node before shipping to
+ // the client. If \c gather_before_delivery is false, only the data from the
+ // root node will be sent to the client without any parallel communication.
+ static void SetDeliverToClientAndRenderingProcesses(
+ bool deliver_to_client, bool gather_before_delivery);
+ // Description:
// Pass the structured-meta-data for determining rendering order for ordered
// compositing.
static void SetOrderedCompositingInformation(
diff --git a/ParaViewCore/ClientServerCore/Rendering/vtkTextSourceRepresentation.cxx b/ParaViewCore/ClientServerCore/Rendering/vtkTextSourceRepresentation.cxx
index 8f0cd99..e7881f7 100644
--- a/ParaViewCore/ClientServerCore/Rendering/vtkTextSourceRepresentation.cxx
+++ b/ParaViewCore/ClientServerCore/Rendering/vtkTextSourceRepresentation.cxx
@@ -167,7 +167,8 @@ int vtkTextSourceRepresentation::ProcessViewRequest(
vtkPVRenderView::SetPiece(inInfo, this,
this->CacheKeeper->GetOutputDataObject(0));
- vtkPVRenderView::SetDeliverToAllProcesses(inInfo, this, true);
+ vtkPVRenderView::SetDeliverToClientAndRenderingProcesses(inInfo, this,
+ /*deliver_to_client=*/ true, /*gather_before_delivery=*/ false);
else if (request_type == vtkPVView::REQUEST_RENDER())
1.7.10.4
