0014198 | ParaView | (No Category) | public | 2013-07-30 16:11 | 2015-01-11 08:24 | ||||
Target Version | Fixed in Version | 4.1 | |||||||
Summary | 0014198: Make it easier to add annotations in the Color Map Editor | ||||||||
Description | Current to add annotations one has to periodically click the "+" button to add new rows. The double-click on items to manually edit them. It should be easier. One should be able to just use "Tab" to edit the next item and if "Tab" is pressed on the last item, the list should just automatically grow. | ||||||||
Project | Sandia | ||||||||
Topic Name | 14198_easy_add_annotations, 14198_easy_add_contour_values | ||||||||
(0031378) Utkarsh Ayachit (administrator) 2013-07-30 16:15 |
commit 49ac4e15875ff37144edd79cfcc91b8b5fb5d876 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Tue Jul 30 16:12:30 2013 -0400 BUG 0014198: Making it easier to add new annotations. Users can now add/edit annotations easily. Simply add the first row using the "+" button and double click to start editing the text. Now by hitting Tab key, one can edit the next item in the table. By hitting Tab key past the last item, one can add new rows to the list as well. Change-Id: I33be54400c9af3e1bdb62bcc3d23042da532c5bc |
(0031380) Utkarsh Ayachit (administrator) 2013-07-31 11:51 |
commit 53bdeb42c163724538b50bf6c8e95733a814f71f Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Tue Jul 30 17:16:21 2013 -0400 Making it easier to add contours. With improvements for BUG 0014198 which made it easier to add annotations by adding a new class for showing expandable tables, updating the panel for the Contour filter to use the same widget. Updated to tests to exercise some of the functionality of the update panel. Change-Id: I69b667b3b428d66310363ea24ce9badfc0f2cc2f |
(0031387) Utkarsh Ayachit (administrator) 2013-08-05 12:21 |
SUMMARY --------------------------------------------- Topics merged into master: 14187_fix_animation_cache_default 14198_easy_add_annotations 14198_easy_add_contour_values fix_manta_benchmark pqContourWidget_better_widget_checking |
(0031410) Alan Scott (manager) 2013-08-09 16:25 |
Nice! Tested master, remote server, Linux. |
2013-07-30 16:11 | Utkarsh Ayachit | New Issue | |
2013-07-30 16:15 | Utkarsh Ayachit | Topic Name | => 14198_easy_add_annotations |
2013-07-30 16:15 | Utkarsh Ayachit | Note Added: 0031378 | |
2013-07-30 16:15 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2013-07-30 16:15 | Utkarsh Ayachit | Fixed in Version | => git-next |
2013-07-30 16:15 | Utkarsh Ayachit | Resolution | open => fixed |
2013-07-30 16:15 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2013-07-31 11:48 | Utkarsh Ayachit | Topic Name | 14198_easy_add_annotations => 14198_easy_add_annotations, 14198_easy_add_contour_values |
2013-07-31 11:51 | Utkarsh Ayachit | Note Added: 0031380 | |
2013-08-05 12:20 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2013-08-05 12:21 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-08-05 12:21 | Utkarsh Ayachit | Note Added: 0031387 | |
2013-08-09 16:25 | Alan Scott | Note Added: 0031410 | |
2013-08-09 16:25 | Alan Scott | Status | customer review => closed |
2013-11-01 13:18 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
2015-01-11 08:24 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 1fc50f6d |
2015-01-11 08:24 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 49ac4e15 |
2015-01-11 08:24 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 53bdeb42 |
