0014178 | ParaView | (No Category) | public | 2013-07-18 20:09 | 2013-11-01 13:18 | ||||
Target Version | 4.1 | Fixed in Version | 4.1 | ||||||
Summary | 0014178: Categorical colors fail for reasonably large size data ranges | ||||||||
Description | I believe that categorical colors are failing if the number of colors needed exceeds the number in the color table. If so, just wrap around the color table and repeat. This is also messing up the Color Legend. * Master, local server, Linux. * Open disk_out_ref.exo. All variables on. Apply. Color by PedigreeElementId. * Color editor. Choose Preset. Spectrum. Close, close. The only color shown is brown. If you try to threshold by PedigreeElementId, there are no values! Also, the Color Legend will be empty. | ||||||||
Project | Sandia | ||||||||
(0031379) Utkarsh Ayachit (administrator) 2013-07-30 16:17 |
Please give it a try after the refactoring of the Color Map Editor. The workflow has changed slightly. One has to add the values to annotate in the "Annotations" widget. Fix for BUG 0014198 makes it easier to add/edit annotations by keeping on editing and hitting tab. Once done, one can setup the colors by loading a preset or manually selecting colors by the double-clicking on the "?" icon. |
(0031385) Utkarsh Ayachit (administrator) 2013-08-05 12:21 |
SUMMARY --------------------------------------------- Topics merged into master: 14187_fix_animation_cache_default 14198_easy_add_annotations 14198_easy_add_contour_values fix_manta_benchmark pqContourWidget_better_widget_checking |
(0031532) Alan Scott (manager) 2013-09-03 21:15 |
I misunderstood what categorical colors are, and how to run them. They are working correctly. |
2013-07-18 20:09 | Alan Scott | New Issue | |
2013-07-18 20:11 | Alan Scott | Summary | Catigorical colors fail for reasonably large size data => Catigorical colors fail for reasonably large size data ranges |
2013-07-18 20:11 | Alan Scott | Summary | Catigorical colors fail for reasonably large size data ranges => Categorical colors fail for reasonably large size data ranges |
2013-07-30 10:12 | Utkarsh Ayachit | Target Version | => 4.1 |
2013-07-30 16:17 | Utkarsh Ayachit | Note Added: 0031379 | |
2013-07-30 16:17 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2013-07-30 16:17 | Utkarsh Ayachit | Fixed in Version | => git-next |
2013-07-30 16:17 | Utkarsh Ayachit | Resolution | open => fixed |
2013-07-30 16:17 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2013-08-05 12:20 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2013-08-05 12:21 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-08-05 12:21 | Utkarsh Ayachit | Note Added: 0031385 | |
2013-09-03 21:15 | Alan Scott | Note Added: 0031532 | |
2013-09-03 21:15 | Alan Scott | Status | customer review => closed |
2013-11-01 13:18 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
