0014162ParaView(No Category)public2013-07-03 13:212013-11-01 13:18
ReporterRobert Maynard
Assigned ToRobert Maynard
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version4.1
Target VersionFixed in Version4.1
Summary0014162: pqFileChooserWidget directory mode drops the last directory
DescriptionI am attempting to use pqFileChooserWidget to select a path for storing temp files in my properties panel, and I am having trouble.
I am using it as follows:
create a custom property panel widget using a pqFileChooserWidget as the ui.
Set setUseDirectoryMode(true)
When selecting a path, the following odd behavior occurs:
1) Select the path the I want
2) click OK
3) in the dialog, the path ONE STEP BELOW the selected path is displayed.
For example: if I select /tmp, the ui will show that / is selected. If I select /tmp/sc01a, the ui shows /tmp as selected.
Could someone provide some information on why this may be occurring?
TagsNo tags attached.
ProjectTBD
Topic Namefilechooser_directory_bug
Typeincorrect functionality
 Relationships
  Notes
(0031134)
2013-07-12 14:07
merged into master.
(0031438)
Robert Maynard (developer)
2013-08-12 12:09
Tested and verified that the file chooser widget works properly in directory mode.
 Issue History
2013-07-03 13:21 Robert Maynard New Issue
2013-07-03 13:21 Robert Maynard Assigned To => Robert Maynard
2013-07-03 13:21 Robert Maynard Topic Name => filechooser_directory_bug
2013-07-03 13:21 Robert Maynard Status backlog => gatekeeper review
2013-07-03 13:21 Robert Maynard Resolution open => fixed
2013-07-12 14:07 Utkarsh Ayachit Fixed in Version => git-master
2013-07-12 14:07 Utkarsh Ayachit Status gatekeeper review => customer review
2013-07-12 14:07 Utkarsh Ayachit Note Added: 0031134
2013-08-12 12:09 Robert Maynard Note Added: 0031438
2013-08-12 12:09 Robert Maynard Status customer review => closed
2013-11-01 13:18 Utkarsh Ayachit Fixed in Version git-master => 4.1
