0014158 | ParaView | (No Category) | public | 2013-07-01 23:05 | 2015-01-11 08:24 | ||||
Target Version | 4.1 | Fixed in Version | 4.1 | ||||||
Summary | 0014158: Update threshold panel to use double-ended slider | ||||||||
Description | Update threshold panel to use double-ended slider. | ||||||||
Project | Sandia | ||||||||
Topic Name | 14158_fix_double_range_slider | ||||||||
Type | feature | ||||||||
(0031114) Utkarsh Ayachit (administrator) 2013-07-02 11:37 |
commit 8107ac4f34730f949b8db912247e06aef4ae862c Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Mon Jul 1 23:05:54 2013 -0400 BUG 0014158: Update threshold panel to use double-ended slider. Updating Threshold panel (i.e. pqDoubleRangeSliderPropertyWidget) to use double ended slider instead of two separate sliders. This overcomes wierd sync and update issues that were common with Threshold panel esp. on Macs. Change-Id: I2afad95c7d582a547c03974da9830554fe320f7c |
(0031131) Utkarsh Ayachit (administrator) 2013-07-12 14:07 |
merged into master. |
(0031427) Alan Scott (manager) 2013-08-09 20:07 |
Tested remote server, Linux, master. |
(0031428) Alan Scott (manager) 2013-08-09 20:13 |
There is a bug in this implementation. Do the following: Linux, master, remote server (I am sure local will show the bug). * Open can.exo. Apply. Make sure you leave Time at 0. * Threshold. Apply. * Now, change to EQPS. The right slider disappears, and we are thresholding from 0 to 0. OK so far. * Move forward one timestep. <bug number 1> - part of the can gets thresholded. This shouldn't happen, right? <bug number 2 (and the more important one)> - It is now impossible to find the max and min of EQPS. You can't find the right slider, and can't move the left one. This needs to be fixed. |
(0031429) Alan Scott (manager) 2013-08-09 20:13 |
Moving to Todo (i.e., bad implementation, needing fixing), setting to Utkarsh, and increasing priority. |
(0031450) Utkarsh Ayachit (administrator) 2013-08-14 13:41 edited on: 2013-08-14 13:43 |
<bug number 1> - part of the can gets thresholded. This shouldn't happen, right? This is exactly as expected. If you show the original can and color by EQPS, you'll see that the thresholded cells had EQPS > 0 and hence they were removed by the filter. <bug number 2> - is indeed a bug. looking into it. |
(0031461) Utkarsh Ayachit (administrator) 2013-08-14 22:57 edited on: 2013-08-14 22:58 |
Alan, Looking at bug #2, here's what's happening. The two sliders overlap on 0. Since the values set for min and max were 0, and for timestep 1 there's a non-zero range for EQPS, with 0 being the min, both the sliders end up over 0 as expected. Now to move the "max" slider, one can either click on the right-half of the slider or type text manually in the right-side entry box. Do similar on the left-half (or entry-box on the left side) to change the minimum. Additionally, I am going to add ability to double click on the empty space on the slider to move the closest slider to that position, this making it possible to easily move the sliders when they overlap, as in this case. |
(0031462) Utkarsh Ayachit (administrator) 2013-08-14 23:01 |
commit b530d0e0cdb97859d406f9e311759cdba6f5809e Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Wed Aug 14 22:56:29 2013 -0400 BUG 0014158. Making it easier to move sliders when they overlap. When the min and max sliders overlap, it's very hard for the users to move them. To make that easier, added new ability to double click on the empty space on the slider widget to move the closest slider to that position. Thus, when the two sliders overlap, the user can double click on the left-side of the two sliders to move the min or right-side for the max slider. Change-Id: I24073cf403661434302ceaf2d7d0caa784f999e6 |
(0031473) Utkarsh Ayachit (administrator) 2013-08-16 13:48 |
Topics merged into master: 0014218_fix_color_preset_issues 13029_fix_auto_apply 14158_fix_double_range_slider 14185_fix_component_name 14204_fix_domains 14233_fix_disconnect_button 14234_fix_trace_views better_disconnect_error_v2 serverside_only_reader (VTK) update_to_master |
(0031529) Alan Scott (manager) 2013-09-03 21:11 |
I agree that bug number 1 isn't really a bug. Bug 2 fixed. Tested Linux, master, remote server. Nice. |
2013-07-01 23:05 | Utkarsh Ayachit | New Issue | |
2013-07-01 23:20 | Utkarsh Ayachit | Topic Name | => 14158_update_threshold_panel |
2013-07-01 23:20 | Utkarsh Ayachit | Type | incorrect functionality => feature |
2013-07-02 11:37 | Utkarsh Ayachit | Note Added: 0031114 | |
2013-07-02 11:37 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2013-07-02 11:37 | Utkarsh Ayachit | Fixed in Version | => git-next |
2013-07-02 11:37 | Utkarsh Ayachit | Resolution | open => fixed |
2013-07-02 11:37 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2013-07-12 14:07 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2013-07-12 14:07 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-07-12 14:07 | Utkarsh Ayachit | Note Added: 0031131 | |
2013-08-09 20:07 | Alan Scott | Note Added: 0031427 | |
2013-08-09 20:07 | Alan Scott | Status | customer review => closed |
2013-08-09 20:13 | Alan Scott | Note Added: 0031428 | |
2013-08-09 20:13 | Alan Scott | Status | closed => backlog |
2013-08-09 20:13 | Alan Scott | Resolution | fixed => reopened |
2013-08-09 20:13 | Alan Scott | Note Added: 0031429 | |
2013-08-09 20:13 | Alan Scott | Status | backlog => todo |
2013-08-09 20:14 | Alan Scott | Priority | normal => high |
2013-08-14 11:04 | Utkarsh Ayachit | Target Version | => 4.1 |
2013-08-14 13:41 | Utkarsh Ayachit | Note Added: 0031450 | |
2013-08-14 13:43 | Utkarsh Ayachit | Note Edited: 0031450 | |
2013-08-14 22:57 | Utkarsh Ayachit | Note Added: 0031461 | |
2013-08-14 22:58 | Utkarsh Ayachit | Note Edited: 0031461 | |
2013-08-14 23:01 | Utkarsh Ayachit | Note Added: 0031462 | |
2013-08-14 23:03 | Utkarsh Ayachit | Topic Name | 14158_update_threshold_panel => 14158_fix_double_range_slider |
2013-08-14 23:03 | Utkarsh Ayachit | Status | todo => gatekeeper review |
2013-08-14 23:03 | Utkarsh Ayachit | Resolution | reopened => fixed |
2013-08-16 13:48 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-08-16 13:48 | Utkarsh Ayachit | Note Added: 0031473 | |
2013-09-03 21:11 | Alan Scott | Note Added: 0031529 | |
2013-09-03 21:11 | Alan Scott | Status | customer review => closed |
2013-11-01 13:18 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
2015-01-11 08:23 | Cory Quammen | Source_changeset_attached | => ParaView master 2ea9c6ec |
2015-01-11 08:24 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master e83e2ab5 |
2015-01-11 08:24 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master b530d0e0 |
2015-01-11 08:24 | Sebastiennn Jourdain | Source_changeset_attached | => ParaView master f8315cfd |
2015-01-11 08:24 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 8107ac4f |
