0014131 | ParaView | (No Category) | public | 2013-06-18 13:19 | 2013-11-01 13:18 | ||||
Reporter | Pat Marion | ||||||||
Assigned To | Pat Marion | ||||||||
Target Version | Fixed in Version | 4.1 | |||||||
Summary | 0014131: Add python refactor changes to ParaView | ||||||||
Description | This issue to to track the python-refactor branch which resolves some python issues in ParaView 4.0 7a6f910 Remove the call to smtrace.print_trace from smstate.trace_state. fc79162 Use the python main context instead of the interactive console for trace. 11c7cde Remove unused methods in pqPythonManager b8e68e6 Remove pqPythonShell::initPythonInerpreter callback. 1fc7abe Initialize Python before constructing the python console d19f1fd Fix the SetParameter API overloads of the vtkPythonProgrammableFilter e492636 Fix: in the programmable filter, delete the function before redefining it afc3965 Add a test for using the Python programmable filter with pvserver af99ee3 Change the behavior of pqPythonShell::pushScript() to split over newlines c946500 Execute python code in the context of the interactive console. 7cbabb7 Don't print a newline when executing a python command in the console. 2ad7938 Add a call to prompt() during the python shell startup 00427e5 Make sure the paraview module is always initialized by pqPythonManager a1fedb9 Disable trace observers when tracing python state in cpstate.py | ||||||||
Project | TBD | ||||||||
Topic Name | 14151-python-refactoring | ||||||||
(0031022) Utkarsh Ayachit (administrator) 2013-06-21 12:13 |
SUMMARY --------------------------------------------- Topics merged into master: 0014077_fix_qttesting_exports 13024-python-debug-leaks-view (VTK) 14132-gl2ps-scalar-bar-fix 14134_nektar_warnings_suppression 14151-python-refactoring add-test-plugin-option-v2 fix-animation-looping follow-data-animation (VTK) forward-to-vtk-master ipython_trivial_producer |
(0031325) Alan Scott (manager) 2013-07-23 22:00 |
Developer tag in git. Closing. |
2013-06-18 13:19 | Pat Marion | New Issue | |
2013-06-18 13:19 | Pat Marion | Assigned To | => Pat Marion |
2013-06-20 11:01 | Pat Marion | Status | backlog => gatekeeper review |
2013-06-20 11:01 | Pat Marion | Resolution | open => fixed |
2013-06-21 12:09 | Utkarsh Ayachit | Topic Name | => 14151-python-refactoring |
2013-06-21 12:12 | Utkarsh Ayachit | Fixed in Version | => git-master |
2013-06-21 12:13 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-06-21 12:13 | Utkarsh Ayachit | Note Added: 0031022 | |
2013-07-23 22:00 | Alan Scott | Note Added: 0031325 | |
2013-07-23 22:00 | Alan Scott | Status | customer review => closed |
2013-11-01 13:18 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
