0014071 | ParaView | (No Category) | public | 2013-05-15 16:13 | 2013-11-01 13:18 | ||||
Assigned To | Sebastien Jourdain | ||||||||
Target Version | Fixed in Version | 4.1 | |||||||
Summary | 0014071: Table to structured grid filter fails remote, multi server | ||||||||
Description | Linux, remote server, 8 servers, master. Open file scalarsBroken.csv. Table to structured grid filter. Select y coord for Y column, and z coord for Z column. Apply. ParaView never returns. | ||||||||
Project | Sandia | ||||||||
Topic Name | table2structured_one_piece_extent_fix | ||||||||
Type | crash | ||||||||
Attached Files | scalarsBroken.csv [^] (157 bytes) 2013-05-15 16:13 | ||||||||
Relationships | ||||||
(0030779) Alan Scott (manager) 2013-05-15 16:22 |
This also fails, without crashing, local server. We get the following error: ERROR: In /projects/viz/paraview/src/ParaView/3.98.2-alan/ParaView3/VTK/Filters/General/vtkTableToStructuredGrid.cxx, line 97 vtkPTableToStructuredGrid (0x1f45cc0): The input table must have exactly 1 rows. Currently it has 8 rows. ERROR: In /projects/viz/paraview/src/ParaView/3.98.2-alan/ParaView3/VTK/Common/ExecutionModel/vtkExecutive.cxx, line 754 vtkPVCompositeDataPipeline (0x1e8d4b0): Algorithm vtkPTableToStructuredGrid(0x1f45cc0) returned failure for request: vtkInformation (0x1ebc910) Debug: Off Modified Time: 133854 Reference Count: 1 Registered Events: (none) Request: REQUEST_DATA ALGORITHM_AFTER_FORWARD: 1 FORWARD_DIRECTION: 0 FROM_OUTPUT_PORT: 0 ERROR: In /projects/viz/paraview/src/ParaView/3.98.2-alan/ParaView3/VTK/Filters/General/vtkTableToStructuredGrid.cxx, line 97 vtkPTableToStructuredGrid (0x1f45cc0): The input table must have exactly 1 rows. Currently it has 8 rows. ERROR: In /projects/viz/paraview/src/ParaView/3.98.2-alan/ParaView3/VTK/Common/ExecutionModel/vtkExecutive.cxx, line 754 vtkPVCompositeDataPipeline (0x1e8d4b0): Algorithm vtkPTableToStructuredGrid(0x1f45cc0) returned failure for request: vtkInformation (0x2fd0d90) Debug: Off Modified Time: 135267 Reference Count: 1 Registered Events: (none) Request: REQUEST_DATA ALGORITHM_AFTER_FORWARD: 1 FORWARD_DIRECTION: 0 FROM_OUTPUT_PORT: 0 ERROR: In /projects/viz/paraview/src/ParaView/3.98.2-alan/ParaView3/VTK/Filters/General/vtkTableToStructuredGrid.cxx, line 97 vtkPTableToStructuredGrid (0x1f45cc0): The input table must have exactly 1 rows. Currently it has 8 rows. ERROR: In /projects/viz/paraview/src/ParaView/3.98.2-alan/ParaView3/VTK/Common/ExecutionModel/vtkExecutive.cxx, line 754 vtkPVCompositeDataPipeline (0x1e8d4b0): Algorithm vtkPTableToStructuredGrid(0x1f45cc0) returned failure for request: vtkInformation (0x2fd0d90) Debug: Off Modified Time: 135297 Reference Count: 1 Registered Events: (none) Request: REQUEST_DATA ALGORITHM_AFTER_FORWARD: 1 FORWARD_DIRECTION: 0 FROM_OUTPUT_PORT: 0 Warning: In /projects/viz/paraview/src/ParaView/3.98.2-alan/ParaView3/VTK/Common/DataModel/vtkDataObject.cxx, line 525 vtkTable (0x1ec30b0): Attempted to ShallowCopy from null. |
(0030780) Alan Scott (manager) 2013-05-15 16:23 |
Changing to high priority. Things shouldn't crash, and this filter is basically useless. |
(0030792) Yumin Yuan (developer) 2013-05-16 08:40 |
Just want to verify if my fixes for bug 13962 broke this. I downloaded and installed 3.98.0 , and used a a good csv file (scalarWorking.csv), I got same error with local server, so this bug was there BEFORE my fixes. |
(0031070) Sebastien Jourdain (manager) 2013-06-25 15:23 |
The missing part is that the user has to specify the whole extent of the data. In that case the extent will be: [0,1,0,1,0,1] as we have 8 rows. 2x2x2 |
(0031090) Sebastien Jourdain (manager) 2013-06-27 12:15 |
commit 1281c9fc01d6aa1fede8bbe6f9e962f92f7933cc Author: Sebastien Jourdain <sebastien.jourdain@kitware.com> Date: Thu Jun 27 12:10:45 2013 -0400 Remove vtkPTableToStructuredGrid to use vtkTableToStructuredGrid instead Change-Id: Ie2401485b43536a395dbc2c77145522aefbbc377 |
(0031098) Utkarsh Ayachit (administrator) 2013-06-28 08:39 |
SUMMARY --------------------------------------------- Topics merged into master: 13791_sliceview_hide_outline 14148_fix_path_issues allow_request_data_to_fail block-icon-cache freeze_python pvw-extend-pipeline-manager pvw-fix-clip-widget pvw-python-friendly-processRMIs pvw-signal-handler-arg simple-py-lookup-tables (VTK) table2structured_one_piece_extent_fix tecplot_extensions --------------------------------------------- |
(0031457) Alan Scott (manager) 2013-08-14 19:20 |
Not sure if this was user error (my bad), or needing to be fixed as listed below, but it now seems to work. As per Seb, used Whole Extent 0,1,0,1,0,1. Tested Linux, master, local server. |
2013-05-15 16:13 | Alan Scott | New Issue | |
2013-05-15 16:13 | Alan Scott | File Added: scalarsBroken.csv | |
2013-05-15 16:19 | Alan Scott | Relationship added | related to 0013962 |
2013-05-15 16:22 | Alan Scott | Note Added: 0030779 | |
2013-05-15 16:23 | Alan Scott | Note Added: 0030780 | |
2013-05-15 16:23 | Alan Scott | Priority | normal => high |
2013-05-16 08:40 | Yumin Yuan | Note Added: 0030792 | |
2013-06-25 15:23 | Sebastien Jourdain | Note Added: 0031070 | |
2013-06-25 15:24 | Sebastien Jourdain | Assigned To | => Sebastien Jourdain |
2013-06-25 15:24 | Sebastien Jourdain | Status | backlog => todo |
2013-06-25 15:24 | Sebastien Jourdain | Note Added: 0031071 | |
2013-06-25 15:24 | Sebastien Jourdain | Status | todo => closed |
2013-06-25 15:24 | Sebastien Jourdain | Resolution | open => fixed |
2013-06-25 15:25 | Sebastien Jourdain | Resolution | fixed => no change required |
2013-06-25 15:26 | Sebastien Jourdain | Status | closed => active development |
2013-06-25 15:26 | Sebastien Jourdain | Note Deleted: 0031071 | |
2013-06-27 12:13 | Sebastien Jourdain | Topic Name | => table2structured_one_piece_extent_fix |
2013-06-27 12:13 | Sebastien Jourdain | Status | active development => gatekeeper review |
2013-06-27 12:15 | Sebastien Jourdain | Note Added: 0031090 | |
2013-06-28 08:38 | Utkarsh Ayachit | Fixed in Version | => git-master |
2013-06-28 08:39 | Utkarsh Ayachit | Note Added: 0031098 | |
2013-06-28 08:39 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-08-14 19:20 | Alan Scott | Note Added: 0031457 | |
2013-08-14 19:20 | Alan Scott | Status | customer review => closed |
2013-11-01 13:18 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
