0014042VTK(No Category)public2013-05-01 16:132014-10-29 09:53
ReporterNil Goyette
Assigned ToDavid Gobbi
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version5.10.0
Target VersionFixed in Version6.2.0
Summary0014042: vtkImageStencilData returns random bad lines
DescriptionI have a mitk::Mesh which I know is a well-defined closed surface because I can see it and, as intructed in [1], vtkFeatureEdges returns 0 bad feature. This mesh looks like http://i.imgur.com/1HWqmmy.jpg. [^] It may be hard to see, but it's a heart countour, with no bottom. The middle volume is empty, the mesh only defines the contour.
So, here's the pipeline
1. A vtkPolyData that I'm pretty sure is valid because in [1], David Gobbi advises to use vtkFeatureEdges and vtkCleanPolyData, both of which return what I want.
2. vtkImageStencilData using vtkPolyDataToImageStencil with tolerance = 1.0
3. Create a binary image with this stencilData using vtkImageStencil
Like the guy in [1], I obtain random lines at the bottom of my polyData. You can see them here http://i.imgur.com/k9jXgg7.jpg. [^] I don't understand where these lines come from. They dissapear when tolerance = 0.0, but I can't set tolerance to 0 because sometime the countour is really thin, so it will dissapear.
Another advice in [1] is to recompile vtk using double in vtkPolyDataToImageStencil, but this is not an option for us. So, what can I do to get rid of these lines?
[1] http://vtk.1045678.n5.nabble.com/Problem-with-vtkPolyDataToImageStencil-td5714947.html [^]
TagsNo tags attached.
ProjectTBD
Typeincorrect functionality
Attached Filesdiff file icon 14042-polydatatoimagestencil-robustness-3.diff [^] (21,608 bytes) 2014-09-15 11:50 [Show Content]
 Relationships
  Notes
(0033333)
David Gobbi (developer)
2014-09-14 00:16
A patch has been attached that should fix the issue. I'll do a bit more testing and make sure it gets into VTK 6.2.
(0033341)
2014-09-15 11:52
Gerrit review page:
http://review.source.kitware.com/#/c/17021/ [^]
(0033672)
2014-10-29 09:53
commit 88ab5f7e3cf33d3781dae3f6d4ba06c1c79bb5b8
 Issue History
2013-05-01 16:13 Nil Goyette New Issue
2014-09-14 00:13 David Gobbi Assigned To => David Gobbi
2014-09-14 00:13 David Gobbi Status backlog => active development
2014-09-14 00:14 David Gobbi File Added: 14042-polydatatoimagestencil-robustness.diff
2014-09-14 00:16 David Gobbi Note Added: 0033333
2014-09-15 11:49 David Gobbi File Deleted: 14042-polydatatoimagestencil-robustness.diff
2014-09-15 11:50 David Gobbi File Added: 14042-polydatatoimagestencil-robustness-3.diff
2014-09-15 11:52 David Gobbi Note Added: 0033341
2014-09-15 11:52 David Gobbi Status active development => gerrit review
2014-10-29 09:53 David Gobbi Note Added: 0033672
2014-10-29 09:53 David Gobbi Status gerrit review => closed
2014-10-29 09:53 David Gobbi Resolution open => fixed
2014-10-29 09:53 David Gobbi Fixed in Version => 6.2.0
