0000140 | VTK | (No Category) | public | 2003-08-13 11:44 | 2011-01-13 17:00 | ||||
Reporter | Mathieu Malaterre | ||||||||
Assigned To | |||||||||
Summary | 0000140: Hybrid/vtkGLUTesselatorTriangleFilter doesn't compile | ||||||||
Description | vtkGLUTesselatorTriangleFilter doesn't compile out of the box on my linux system. Please find the modified files: http://www.creatis.insa-lyon.fr/~malaterre/vtk/vtkGLUTesselatorTriangleFilter.cxx [^] http://www.creatis.insa-lyon.fr/~malaterre/vtk/vtkGLUTesselatorTriangleFilter.h [^] Or if easier to use a patch, done with $ cvs -z3 diff -u > glut.patch http://www.creatis.insa-lyon.fr/~malaterre/vtk/glut.patch [^] This file still need some testing on sgi/freebsd... (see #ifdef in the patch) | ||||||||
(0000095) Mathieu Malaterre (developer) 2003-08-13 12:38 |
After some google search g++ (cygwin) optimize code if one use: #define _stdcall __attribute__((__stdcall__)) |
(0000345) Mathieu Malaterre (developer) 2003-12-12 10:24 |
GLU is not used in VTK anymore. Remove this class |
2007-08-04 16:13 | Berk Geveci | Assigned To | Eric Stanton => |
2007-08-04 16:13 | Berk Geveci | Priority | high => normal |
2007-08-04 16:13 | Berk Geveci | Severity | feature => minor |
2007-08-04 16:13 | Berk Geveci | Status | tabled => closed |
2007-08-04 16:13 | Berk Geveci | Resolution | no change required => won't fix |
2007-08-04 16:13 | Berk Geveci | Summary | Goodsite => Hybrid/vtkGLUTesselatorTriangleFilter doesn't compile |
2007-08-04 16:14 | Berk Geveci | Note Deleted: 0008210 | |
2007-08-04 16:14 | Berk Geveci | Project | ParaView => VTK |
2010-11-29 17:59 | Mathieu Malaterre | Source_changeset_attached | => VTK master 3539c87f |
2011-01-13 17:00 | Source_changeset_attached | => VTK master a2bd8391 | |
2011-01-13 17:00 | Source_changeset_attached | => VTK master 020ef709 | |
