0013990 | ParaView | (No Category) | public | 2013-04-03 06:45 | 2013-05-18 20:00 | ||||
Target Version | Fixed in Version | 4.0 | |||||||
Summary | 0013990: Properties panel: Search doesn't behave correctly. | ||||||||
Description | * Create Sphere * Apply * Type "Opacity" is search text * Now change Opacity using the slider. As soon as the slider is moved the panel shows all other widgets -- this is incorrect. | ||||||||
Tags | New Panels | ||||||||
Project | Sandia | ||||||||
Topic Name | refactor_panels | ||||||||
(0030511) Kyle Lutz (viewer) 2013-04-03 13:45 |
Merge topic '13990-fix-panel-search' into next 0a49447 Respect current search string when toggling advanced button |
(0030523) Sebastien Jourdain (manager) 2013-04-05 09:03 |
Merged into master |
(0030554) Utkarsh Ayachit (administrator) 2013-04-11 08:10 |
Another bug now surfaced. * Create Sphere, Apply * Type "opac" in search text. You should see 2 sliders: :Opacity, Backface Opacity. * Start changing "Opacity" using the slider, "Backface Opacity" disappears!!! |
(0030591) Utkarsh Ayachit (administrator) 2013-04-22 17:20 |
commit 17a9b733b119c44780fc10e153e0606e26101dd4 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Fri Apr 12 12:05:25 2013 -0400 Refactoring Properties Panel (pqPropertiesPanel). This commit refactors pqPropertiesPanel for better usability and visual appearance. The changes can be summarized as follows: - Added a new class, pqProxyWidget, which creates the 'auto-generated' panel for any proxy. pqPropertiesPanel now uses this class to create the panels for source/display. - Property group were extended to add ability to group properties on non-exposed properties (as demonstrated by Wavelet source). The visual appearance of property groups was also changed. Also fixed leaks in ServerManager relating to groups and new property attributes that were added in past for the panels. - pqPropertyWidgetDecorator was added to provide a mechanism to add custom logic to widgets which having to create new widget types. pqPropertyWidgetDecorator can be used to control widget visibility, for example. - Converted custom panels for for several filters to be non-custom i.e. simply be auto-generated. - Added mechanism for plugins to provide new pqPropertyWidget types for properties, property groups or new pqPropertyWidgetDecorator types. Added an example under Examples that demonstrates the use of the same. - Added infrastructure to print debug messages when certain environment variables are set (pqDebug). - Removing obsolete SummaryPanel elements. - Updated tests to work with these changes. Change-Id: I49e82525ba666380b265a7f2075207dc2cd6f452 |
(0030616) Utkarsh Ayachit (administrator) 2013-04-25 09:24 |
SUMMARY --------------------------------------------- Topics merged into master: 13450_update_tests_to_use_new_panels (VTK) 14023-plot3d-function-support 14026_catalyst_python_warning 14032_fix_CoProcessingTestInput fix_protobuf_try_compiles pvw-python-refactoring pvw-remove-example refactor_panels (VTK) update_vtk_master zoom-to-data-icon fix_cmake_2.8.10_plugins_issue |
(0030647) Alan Scott (manager) 2013-04-30 20:08 |
Tested master, Linux, remote server. I also tested the bug that shows up in the notes below. |
2013-04-03 06:45 | Utkarsh Ayachit | New Issue | |
2013-04-03 06:45 | Utkarsh Ayachit | Assigned To | => Kyle Lutz |
2013-04-03 06:46 | Utkarsh Ayachit | Tag Attached: New Panels | |
2013-04-03 12:55 | Kyle Lutz | Status | backlog => todo |
2013-04-03 12:55 | Kyle Lutz | Status | todo => active development |
2013-04-03 13:45 | Kyle Lutz | Topic Name | => 13990-fix-panel-search |
2013-04-03 13:45 | Kyle Lutz | Note Added: 0030511 | |
2013-04-03 13:45 | Kyle Lutz | Status | active development => gatekeeper review |
2013-04-03 13:45 | Kyle Lutz | Resolution | open => fixed |
2013-04-05 09:03 | Sebastien Jourdain | Status | gatekeeper review => customer review |
2013-04-05 09:03 | Sebastien Jourdain | Note Added: 0030523 | |
2013-04-11 08:10 | Utkarsh Ayachit | Note Added: 0030554 | |
2013-04-11 08:10 | Utkarsh Ayachit | Status | customer review => todo |
2013-04-22 17:19 | Utkarsh Ayachit | Assigned To | Kyle Lutz => Utkarsh Ayachit |
2013-04-22 17:20 | Utkarsh Ayachit | Topic Name | 13990-fix-panel-search => refactor_panels |
2013-04-22 17:20 | Utkarsh Ayachit | Note Added: 0030591 | |
2013-04-22 17:20 | Utkarsh Ayachit | Status | todo => gatekeeper review |
2013-04-22 17:20 | Utkarsh Ayachit | Fixed in Version | => git-next |
2013-04-25 09:22 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2013-04-25 09:24 | Utkarsh Ayachit | Note Added: 0030616 | |
2013-04-25 09:24 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-04-30 20:08 | Alan Scott | Note Added: 0030647 | |
2013-04-30 20:08 | Alan Scott | Status | customer review => closed |
2013-05-18 20:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.0 |
