0013978 | ParaView | (No Category) | public | 2013-03-28 17:35 | 2016-08-12 09:59 | ||||
Assigned To | Dave DeMarle | ||||||||
Summary | 0013978: xdmf -binary files crashes with 7 time steps or more. | ||||||||
Description | When I wrap xdmf around numerous time variable binary files, ParaView crashes when deleting this file. Linux, local server, master (and 3.98.1). Test dataset is one I voodoo'd up. It basically has 8 4 byte floats that are 0 (i.e., 0x00000000). Dataset is attached, and is called stl-timestep-crash. * Open crash-opening-seven.xmf. * Delete crash-opening-seven.xmf. It will crash. | ||||||||
Project | Sandia | ||||||||
Type | crash | ||||||||
Attached Files | stl-timestep-crash.tar.gz [^] (885 bytes) 2013-03-28 17:35 | ||||||||
(0030637) Sebastien Jourdain (manager) 2013-04-30 15:44 |
Didn't manage to reproduce the crash more than once... Hence I let it to Utkarsh on its Linux computer. |
(0030734) Utkarsh Ayachit (administrator) 2013-05-09 09:50 |
Seems to be a Xdmf bug. Here's the invalid write call-stack that causes issues on delete. ==18297== Invalid write of size 4 ==18297== at 0x2A0F01E8: void XdmfArrayCopy<float, double>(float*, long long, double*, long long, int, long long) (XdmfArrayCopyMacro.h:41) ==18297== by 0x2A0E927A: XdmfArray::SetValues(long long, char const*, long long, long long) (XdmfArray.cxx:604) ==18297== by 0x2A0FCA2F: XdmfValuesXML::Read(XdmfArray*) (XdmfValuesXML.cxx:53) ==18297== by 0x2A10BA70: XdmfDataItem::Update() (XdmfDataItem.cxx:539) ==18297== by 0x2A1203C9: XdmfTime::UpdateInformation() (XdmfTime.cxx:108) ==18297== by 0x2A11A412: XdmfGrid::UpdateInformation() (XdmfGrid.cxx:435) ==18297== by 0x1E835535: vtkXdmfDomain::vtkXdmfDomain(XdmfDOM*, int) (vtkXdmfReaderInternal.cxx:227) ==18297== by 0x1E83519E: vtkXdmfDocument::SetActiveDomain(int) (vtkXdmfReaderInternal.cxx:178) ==18297== by 0x1E82912A: vtkXdmfReader::PrepareDocument() (vtkXdmfReader.cxx:216) ==18297== by 0x1E8292B4: vtkXdmfReader::RequestDataObject(vtkInformationVector*) (vtkXdmfReader.cxx:233) ==18297== by 0x1E8287DF: vtkXdmfReader::ProcessRequest(vtkInformation*, vtkInformationVector**, vtkInformationVector*) (vtkXdmfReader.cxx:144) |
(0031565) Utkarsh Ayachit (administrator) 2013-09-12 14:46 |
Assigning to Dave to test after the Xdmf reader has been updated to Xdmf 3.0. |
(0038373) Kitware Robot (administrator) 2016-08-12 09:59 |
2013-03-28 17:35 | Alan Scott | New Issue | |
2013-03-28 17:35 | Alan Scott | File Added: stl-timestep-crash.tar.gz | |
2013-04-30 15:34 | Sebastien Jourdain | Assigned To | => Sebastien Jourdain |
2013-04-30 15:34 | Sebastien Jourdain | Status | backlog => todo |
2013-04-30 15:34 | Sebastien Jourdain | Status | todo => active development |
2013-04-30 15:44 | Sebastien Jourdain | Note Added: 0030637 | |
2013-04-30 15:44 | Sebastien Jourdain | Assigned To | Sebastien Jourdain => Utkarsh Ayachit |
2013-04-30 15:45 | Sebastien Jourdain | Status | active development => todo |
2013-05-09 09:50 | Utkarsh Ayachit | Note Added: 0030734 | |
2013-09-12 14:45 | Utkarsh Ayachit | Assigned To | Utkarsh Ayachit => Dave DeMarle |
2013-09-12 14:46 | Utkarsh Ayachit | Note Added: 0031565 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038373 | |
2016-08-12 09:59 | Kitware Robot | Status | todo => closed |
