0013942 | ParaView | (No Category) | public | 2013-03-14 10:19 | 2014-08-29 11:00 | ||||
Reporter | Alejandro Ribes | ||||||||
Summary | 0013942: "FitAll" function in python scripting | ||||||||
Description | Hello, I have a request concerning the function that set the viewing position so that all visible datasets in the selected 3D view are within the viewing frustum. This function is the first icon in the Camera Control Toolbar. I would like to use this function when scripting in python. Can you expose this function via a "FitAll" method or something similar? I know there exists a ResetCamera function but it seems that does not correspond to what I want. Exemple: _RenderView = GetRenderView() _RenderView.CenterAxesVisibility = 0 _RenderView.CenterOfRotation = [2.05, 2.05, 2.13] _RenderView.CameraViewUp = [-0.1462842057166934, -0.63184311527201897, -0.76116700456679443] _RenderView.CameraPosition = [4.3574016706599696, 7.6016996854983274, -3.0256734058706636] _RenderView.CameraClippingRange = [2.9513133656308672, 13.226048282992661] _RenderView.CameraFocalPoint = [2.9930930754568661, 1.7779227807543228, 2.0708298819357598] The last 4 commands of this code are necessary to do the "FitAll" BUT they are dependent on the mesh and then not adapted to a pure scripting environment. Thanks in advance, Alejandro. | ||||||||
Project | ParaViS | ||||||||
Type | feature | ||||||||
(0030505) Utkarsh Ayachit (administrator) 2013-04-03 07:10 |
Alejandro, That's exactly what "ResetCamera()" should do. What is the problem you're seeing with ResetCamera()? The first icon in the Camera toolbar, indeed calls the same method as the ResetCamera() call. |
(0032623) Vadim SANDLER (reporter) 2014-05-07 03:50 |
Hello Utkarsh, As I understand a ResetCamera()method doesn’t change the camera position, in the result of the presented below actions a presentation is not visible: v = GetActiveView() c = Cone() representation = Show() Render() v.CameraPosition = [0,0,0] v.ResetCamera() Render() Required a method which sets the camera parameters so that all displayed presentations can be seen. Regards, Roman |
(0032624) Utkarsh Ayachit (administrator) 2014-05-07 09:24 |
Roman, The only reason the specific code fails is because when you change CameraPosition to [0, 0, 0], the CameraFocalPoint is by default [0, 0, 0] too and then VTK totally gets lost since it doesn't have any view direction to work with. ResetCamera will indeed update both, the CameraPosition and the CameraFocalPoint, however it does need a valid view direction to start with. Utkarsh |
(0032713) Vadim SANDLER (reporter) 2014-06-03 04:26 |
Utkarsh, Thanks you for the detailed explanations. This issue can be closed. Roman. |
2013-03-14 10:19 | Alejandro Ribes | New Issue | |
2013-04-03 07:10 | Utkarsh Ayachit | Note Added: 0030505 | |
2014-05-07 03:50 | Vadim SANDLER | Note Added: 0032623 | |
2014-05-07 09:24 | Utkarsh Ayachit | Note Added: 0032624 | |
2014-06-03 04:26 | Vadim SANDLER | Note Added: 0032713 | |
2014-06-05 11:30 | Joachim Pouderoux | Resolution | open => fixed |
2014-06-05 11:30 | Joachim Pouderoux | Description Updated | |
2014-06-08 12:11 | Utkarsh Ayachit | Status | backlog => closed |
2014-06-08 12:11 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2014-06-08 12:11 | Utkarsh Ayachit | Fixed in Version | => git-master |
2014-06-17 09:21 | Utkarsh Ayachit | Target Version | => 4.2 |
2014-08-29 11:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
