0013937 | ParaView | (No Category) | public | 2013-03-11 19:06 | 2016-08-12 09:59 | ||||
Summary | 0013937: Large screenshot of parallel coordinates broken | ||||||||
Description | When you save a screenshot of a parallel coordinates view that is larger than the render window, the result is mangled. ParaView is clearly making tiled images, but the viewports for each image is incorrect and the result in mangled. To replicate, do the following. 1. Load disk_out_ref with all variables on. 2. Run Plot Data filter. 3. Change the view to the parallel coordinates view. 4. File -> Save Screenshot. For the resolution, select something larger than the default. 5. The resulting image will be incorrect. Attached is the image I got. | ||||||||
Project | TBD | ||||||||
Attached Files | TiledPCScreenshot.png [^] (485,223 bytes) 2013-03-11 19:06 | ||||||||
(0038360) Kitware Robot (administrator) 2016-08-12 09:59 |
2013-03-11 19:06 | Ken Moreland | New Issue | |
2013-03-11 19:06 | Ken Moreland | File Added: TiledPCScreenshot.png | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038360 | |
