0013933 | ParaView | (No Category) | public | 2013-03-09 21:44 | 2015-01-11 08:27 | ||||
Target Version | Fixed in Version | 4.0 | |||||||
Summary | 0013933: InSitu Python scripts should not check for valid array names | ||||||||
Description | InSitu Python scripts should not check for valid array names. There are several occasions when we raise errors if the user tried to use a non-present array. This should not happen in insitu mode. | ||||||||
Project | Sandia-Catalyst | ||||||||
Topic Name | 13933_fix_python_missing_arrays | ||||||||
(0030448) Utkarsh Ayachit (administrator) 2013-03-18 16:40 |
commit 461501c1d0f3af7bd8d4193bfaf5b8336755449a Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Mon Mar 18 16:35:16 2013 -0400 BUG 0013933. Allow non-present arrays in Python scripts. "ColorArrayName" property no longer checks the validity of the array specified so long as the array is specified as a tuple (<attribute>, <name>). It will check (and fail if array not found) when the user simply specifies the array name as a string. Updated Python trace to ensure that for "ColorArrayName" we indeed trace out a tuple rather than just the arrayname. Also cleaned up vtkPVOptions to expose publicly accessed enum. Updated servermanager to use the enum rather than the hex values. Change-Id: I219e83ba58b825e40bb4c5a32b69207ff57d9d3c |
(0030449) Utkarsh Ayachit (administrator) 2013-03-18 16:48 |
ColorArrayName can be set in two ways e.g., # ---(a)---- foo.ColorArrayName = "RTData" # ---(b)---- foo.ColorArrayName = ("POINT_DATA", "RTData") If (a) is used, ParaView Python will need to check the available arrays to determine the attribute type. Hence we raise test for arrays and raise exceptions if the array is not found in the local data information as earlier. If (b) is used, ParaView Python will no longer check the available arrays and simply update the property since all information is provided to the call. CoProcessing scripts should use (b) form to overcome errors due to locally missing arrays. However form (a) also avoid raising of errors in SymmetricMode (which is ON for CoProcessing). Also updated Python tracing/state saving mechanism to save the (<attribute>,<name>) tuple for ColorArrayName rather than just the array name. |
(0030450) Utkarsh Ayachit (administrator) 2013-03-18 16:50 |
commit 617617f38b1773f5912ceb9c4f338767209b8166 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Mon Mar 18 16:48:35 2013 -0400 BUG 0013933. Ensure ColorArrayName doesn't raise exceptions. Ensure that older scripts that simply set arraynames for ColorArrayName property don't raise exceptions in symmetric-mpi mode i.e. coprocessing mode. Change-Id: I4b15275ac54ced7b5facb969f20f83fb300b346f |
(0030458) Utkarsh Ayachit (administrator) 2013-03-22 10:45 |
SUMMARY --------------------------------------------- Topics merged into master: 0013949-web-enable-dependent-option 13933_fix_python_missing_arrays 13965_paraview_ghost_cell_issue catalyst_essentials_edition composite-data-display-attributes (VTK) crosscompilation_fixes fix_fortran_mac_issues fix_gmv_test remove-legacy-large-int-float web_data_prober_rickshaw |
(0032064) Alan Scott (manager) 2013-12-24 19:39 |
Old customer review bug. Closing untested. |
2013-03-09 21:44 | Utkarsh Ayachit | New Issue | |
2013-03-09 21:44 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2013-03-09 21:45 | Utkarsh Ayachit | Status | backlog => todo |
2013-03-18 16:40 | Utkarsh Ayachit | Topic Name | => 13933_fix_python_missing_arrays |
2013-03-18 16:40 | Utkarsh Ayachit | Note Added: 0030448 | |
2013-03-18 16:40 | Utkarsh Ayachit | Status | todo => gatekeeper review |
2013-03-18 16:40 | Utkarsh Ayachit | Fixed in Version | => git-next |
2013-03-18 16:40 | Utkarsh Ayachit | Resolution | open => fixed |
2013-03-18 16:48 | Utkarsh Ayachit | Note Added: 0030449 | |
2013-03-18 16:50 | Utkarsh Ayachit | Note Added: 0030450 | |
2013-03-22 10:45 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2013-03-22 10:45 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-03-22 10:45 | Utkarsh Ayachit | Note Added: 0030458 | |
2013-05-18 20:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.0 |
2013-12-24 19:39 | Alan Scott | Note Added: 0032064 | |
2013-12-24 19:39 | Alan Scott | Status | customer review => closed |
2015-01-11 08:27 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 3c938fa9 |
2015-01-11 08:27 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 617617f3 |
2015-01-11 08:27 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 461501c1 |
