0013930 | ParaView | (No Category) | public | 2013-03-07 20:11 | 2013-05-18 20:00 | ||||
Reporter | Andy Bauer | ||||||||
Assigned To | Andy Bauer | ||||||||
Target Version | Fixed in Version | 4.0 | |||||||
Summary | 0013930: parallel xml writers reorder arrays improperly if process 0 doesn't have any points | ||||||||
Description | Run the following with pvbatch with more than 1 process and look at the ordering of the arrays in the output files: ========= try: paraview.simple except: from paraview.simple import * paraview.simple._DisableFirstRenderCameraReset() Line1 = Sphere() Elevation1 = Elevation() Elevation1.LowPoint = [-50.0, 0.0, 0.0] Elevation1.HighPoint = [50., 0.0, 0.0] Calculator1 = Calculator() Calculator1.Function = '1' Calculator1.ResultArrayName = 'b' Calculator2 = Calculator() Calculator2.Function = '1' Calculator2.ResultArrayName = 'a' Calculator3 = Calculator() Calculator3.Function = '1' Calculator3.ResultArrayName = 'c' ProcessIdScalars() Threshold1 = Threshold() Threshold1.Scalars = ['POINTS', 'ProcessId'] Threshold1.ThresholdRange = [0.79, 1.0] w = XMLPUnstructuredGridWriter() w.FileName = 'junk.pvtu' w.UpdatePipeline() | ||||||||
Project | Catalyst | ||||||||
Topic Name | 13930_XMLP_writers | ||||||||
(0030433) Utkarsh Ayachit (administrator) 2013-03-14 10:39 |
SUMMARY --------------------------------------------- Topics merged into master: 0013926-webgl-support 0013940-enable-paraview-web-build 13927_fix_text_bounding_boxes 13928-print-monitors 13930_XMLP_writers 13938_blot_color_table 13939-vr-cache-state (VTK) composite-data-display-attributes fix-ordered-composite-distributor-return fix_unnecessary_rebuilds (VTK) update_vtk_master |
(0030516) Andy Bauer (developer) 2013-04-04 11:12 |
it works as desired now. |
2013-03-07 20:11 | Andy Bauer | New Issue | |
2013-03-07 20:11 | Andy Bauer | Assigned To | => Andy Bauer |
2013-03-08 11:12 | Andy Bauer | Status | backlog => todo |
2013-03-08 11:12 | Andy Bauer | Status | todo => active development |
2013-03-10 14:05 | Andy Bauer | Topic Name | => 13930_XMLP_writers |
2013-03-10 14:05 | Andy Bauer | Status | active development => gatekeeper review |
2013-03-10 14:05 | Andy Bauer | Resolution | open => fixed |
2013-03-14 10:38 | Utkarsh Ayachit | Fixed in Version | => git-master |
2013-03-14 10:39 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-03-14 10:39 | Utkarsh Ayachit | Note Added: 0030433 | |
2013-04-04 11:12 | Andy Bauer | Note Added: 0030516 | |
2013-04-04 11:12 | Andy Bauer | Status | customer review => closed |
2013-05-18 20:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.0 |
