0013919 | ParaView | (No Category) | public | 2013-02-27 23:41 | 2016-08-12 09:59 | ||||
Product Version | 3.98.1 | ||||||||
Summary | 0013919: h5part reader should not allow illogical state | ||||||||
Description | The h5part reader should not allow illogical state. In this particular case, I am referring to turning some variables on, and having either the Xarray, Yarray or Zarray set to a variable that is turned off. Example: * Linux, remote server (I am sure local server will do), 3.98.1 * Load particles.h5part. (ask me for the dataset). * Set Xarray == x, Yarray == Fx, Zarray == Fx. * Turn all variables off. Turn on type, vx and x. * Apply. <<Bug>> this should not be allowed. We are using the variable Fx that is not turned on. | ||||||||
Project | Sandia | ||||||||
(0038356) Kitware Robot (administrator) 2016-08-12 09:59 |
2013-02-27 23:41 | Alan Scott | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038356 | |
