0013821 | ParaView | (No Category) | public | 2013-01-24 18:46 | 2015-01-11 08:28 | ||||
Target Version | Fixed in Version | 3.98.1 | |||||||
Summary | 0013821: vtkRenderingFreeTypeObjectFactory leaks in release builds of ParaView | ||||||||
Description | In release builds of ParaView with Python enabled, certain executables leak vtkRenderingFreeTypeObjectFactory on exiting. | ||||||||
Project | Kitware | ||||||||
Topic Name | 13821_fix_leaks_on_exit | ||||||||
(0030237) Utkarsh Ayachit (administrator) 2013-01-24 18:53 |
commit 1554994981412f49bfebd42a9c3db613f88c88d9 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Thu Jan 24 18:47:04 2013 -0500 BUG 0013821. Fixed vtkRenderingFreeTypeObjectFactory leaks. In certain cases, vtkRenderingFreeTypeObjectFactory leaked when application would quit (only in release builds with gcc).The problem was that while vtkRenderingFreeType_AutoInit_Construct() would get called almost 11/12 times, vtkRenderingFreeType_AutoInit_Destruct() was only getting called once. Which resulted in vtkRenderingFreeTypeObjectFactory not being unregistered and hence leaked. Now the extra reference maintained to vtkRenderingFreeTypeObjectFactory instance itself is unnecessary, since vtkObjectFactory::RegisterFactor() maintains a reference and cleans the reference up when exiting. Cleaning this extra reference overcomes the issue altogether. Change-Id: I878a1c364ac3f1fd729ff06aa9eb3f4191e8660b |
(0030261) Utkarsh Ayachit (administrator) 2013-01-26 10:27 |
SUMMARY --------------------------------------------- Topics merged into master: 0013365-huge-state-file (VTK) 0013470-CTH-AMR-OutlineFilter 13311_fix_time_marker 13784_cleanup_chart_settings_dialog 13799_comparative_view_fixes 13811_fix_3Dwidgets (VTK) 13817_fix_memory_issues 13818_fix_plot_min_max (VTK) 13821_fix_leaks_on_exit 13824_fix_calculator PvxFullScreenBorders vr-fixInteractors vr-missingIncludes |
2013-01-24 18:46 | Utkarsh Ayachit | New Issue | |
2013-01-24 18:46 | Utkarsh Ayachit | Project | Sandia => Kitware |
2013-01-24 18:53 | Utkarsh Ayachit | Topic Name | => 13821_fix_leaks_on_exit |
2013-01-24 18:53 | Utkarsh Ayachit | Note Added: 0030237 | |
2013-01-24 18:53 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2013-01-24 18:53 | Utkarsh Ayachit | Fixed in Version | => git-next |
2013-01-24 18:53 | Utkarsh Ayachit | Resolution | open => fixed |
2013-01-24 18:53 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2013-01-26 10:27 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2013-01-26 10:27 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-01-26 10:27 | Utkarsh Ayachit | Note Added: 0030261 | |
2013-01-30 10:40 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.1 |
2013-02-11 16:02 | Utkarsh Ayachit | Status | customer review => closed |
2015-01-09 13:55 | Utkarsh Ayachit | Source_changeset_attached | => VTK master b4e5b70a |
2015-01-09 13:55 | Utkarsh Ayachit | Source_changeset_attached | => VTK master 15549949 |
2015-01-09 13:56 | Utkarsh Ayachit | Source_changeset_attached | => VTK master e8dd8921 |
2015-01-11 08:28 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 342c22c9 |
2015-01-11 08:28 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 603349bf |
