0013820 | ParaView | (No Category) | public | 2013-01-24 12:11 | 2016-08-12 09:59 | ||||
Reporter | Alejandro Ribes | ||||||||
Product Version | 3.98.1 | ||||||||
Summary | 0013820: ParaView filters and non-conservation of the Representation | ||||||||
Description | Hello, In ParaView the representation of an object is "non-conservative". I will explain that with an example: 1) I open a mesh, then select "Surface with edges" as its representation. 2) I apply a Clip filter to this mesh. 3) The representation of the resulting clip is not "Surface with edges" but "Surface". This behaviour is not what the users expect, it is also general and not only for the Clip filter. I would like to have a "representation conservation" in ParaView. Regards, Alejandro. | ||||||||
Project | ParaViS | ||||||||
Type | usability | ||||||||
(0038319) Kitware Robot (administrator) 2016-08-12 09:59 |
2013-01-24 12:11 | Alejandro Ribes | New Issue | |
2013-03-12 09:13 | Utkarsh Ayachit | Status | backlog => todo |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038319 | |
2016-08-12 09:59 | Kitware Robot | Status | todo => closed |
