0013796 | ParaView | (No Category) | public | 2013-01-16 18:28 | 2013-01-30 10:40 | ||||
Assigned To | Marcus D. Hanwell | ||||||||
Target Version | Fixed in Version | 3.98.1 | |||||||
Summary | 0013796: Chart axes (left and right side) are out of sync | ||||||||
Description | * Linux, local server, master. * Open can.exo. All variables on. Apply. * Plot over line filter. Apply. * On the properties tab, slide to the bottom. Now, turn all variables on. Turn all variables off. * Turn on Displ (Mag). Turn on Vel (Mag). * Highlight Vel (Mag) (i.e., click on the word VEL, which will highlight the whole line). * On Chart Axes, select Bottom-Right. * Right click/drag the 2d window. The left and right axes will move out of sync. This bug is hard to replicate. If you can't replicate it, close ParaView and start again. | ||||||||
Project | Sandia | ||||||||
Topic Name | 13796-chartxy-plot-corner-bug | ||||||||
(0030155) Alan Scott (manager) 2013-01-16 18:29 |
Changing to High priority, since we are going to try to fix it for the 3.98.1 release. |
(0030197) Marcus D. Hanwell (developer) 2013-01-18 18:05 |
I can reproduce this locally, and should have a fix soon. |
(0030199) Marcus D. Hanwell (developer) 2013-01-19 14:12 |
Pushed topic to Gerrit for review in VTK, pushed matching topics to next that address this issue. A new special case was required for when there are only plots in the bottom-left and bottom-right (and have never been any in the top-left/right). |
(0030200) Marcus D. Hanwell (developer) 2013-01-19 14:13 |
http://review.source.kitware.com/#/t/1967/ [^] is the VTK topic (added Utkarsh as a reviewer). |
(0030210) Utkarsh Ayachit (administrator) 2013-01-22 13:29 |
merged into master, if applicable. |
(0030214) Alan Scott (manager) 2013-01-22 14:16 |
I believe this one is fixed (it presented itself inconsistently in initial testing). If not, I will reopen. Tested local server, master, Linux. |
2013-01-16 18:28 | Alan Scott | New Issue | |
2013-01-16 18:29 | Alan Scott | Note Added: 0030155 | |
2013-01-16 18:29 | Alan Scott | Priority | normal => high |
2013-01-17 11:35 | Utkarsh Ayachit | Assigned To | => Marcus D. Hanwell |
2013-01-18 17:13 | Marcus D. Hanwell | Status | backlog => todo |
2013-01-18 17:13 | Marcus D. Hanwell | Status | todo => active development |
2013-01-18 18:05 | Marcus D. Hanwell | Note Added: 0030197 | |
2013-01-19 14:12 | Marcus D. Hanwell | Topic Name | => 13796-chartxy-plot-corner-bug |
2013-01-19 14:12 | Marcus D. Hanwell | Note Added: 0030199 | |
2013-01-19 14:12 | Marcus D. Hanwell | Status | active development => gatekeeper review |
2013-01-19 14:12 | Marcus D. Hanwell | Resolution | open => fixed |
2013-01-19 14:13 | Marcus D. Hanwell | Note Added: 0030200 | |
2013-01-22 13:29 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-01-22 13:29 | Utkarsh Ayachit | Note Added: 0030210 | |
2013-01-22 13:30 | Utkarsh Ayachit | Fixed in Version | => git-master |
2013-01-22 14:16 | Alan Scott | Note Added: 0030214 | |
2013-01-22 14:16 | Alan Scott | Status | customer review => closed |
2013-01-30 10:40 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.1 |
