0013776 | ParaView | (No Category) | public | 2013-01-08 18:16 | 2015-01-11 08:28 | ||||
Target Version | Fixed in Version | 4.1 | |||||||
Summary | 0013776: Opacity color editor needs update call | ||||||||
Description | There is a bug in the opacity color editor, where we need an update somewhere. Here is how to replicate: Linux, local server, master. Open can.exo, all vars on, Apply. Last time step. Color by DISPL. Color Editor. Enable Opacity Function. Apply. >> This is correct. Above the 'b' in the word Enable of Enable Opacity Function, click on the line. Drag this point way up and somethat left. Apply. >> Nothing happened. This is incorrect. Click on the point you created. Delete it. (Hit the delete key). Close. Reopen the color editor. >> Point has reappeared. This is incorrect. Marking high, since I think it will be easy to fix, and it makes the opacity editor basically unusable. | ||||||||
Tags | ColorMap | ||||||||
Project | Sandia | ||||||||
Topic Name | 13776_fix_lut_updates | ||||||||
Relationships | ||||||
(0030267) Utkarsh Ayachit (administrator) 2013-01-28 16:51 |
commit fa1048757644fc825c326b26a77ac7bd2b87dc1e Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Mon Jan 28 16:49:58 2013 -0500 BUG 0013776. Fixed mtime computation. vtkDiscretizableColorTransferFunction was not updating its MTime when the optional ScalarOpacityFunction itself was modified. That was resulting in the LUT not being regenerated on changes to ScalarOpacityFunction, manifested in BUG# 13776. This patch address that issue. Change-Id: If1b63710a6739870f55b089aabc38b7c93c0e493 |
(0030277) Utkarsh Ayachit (administrator) 2013-01-30 10:21 |
SUMMARY --------------------------------------------- Topics merged into master: (VTK) 13776_fix_lut_updates 13814_coprocessing_fix_auto_rescale (VTK) 13826-FixPathUnescape 13830_fix_progress fix_visitbridge_install_rules fix_warnings ParaViewWeb_2.0 (VTK) vtk_master |
(0030330) Alan Scott (manager) 2013-02-11 18:45 |
There are two actual bugs in this bug report. Bug number 1, where Opacity isn't changing, has been fixed. Tested Linux, remote server, 3.98.1. Bug number 2 is still there. You cannot delete points in the middle of the Opacity graph. |
(0031557) Utkarsh Ayachit (administrator) 2013-09-12 13:18 |
Alan, I could not reproduce BUG #2. Note that the mouse pointer must be within the widget when hitting the "Del" key or the key is not received by the widget and hence it may not be deleting. Do you think it will help to show a border around the widget when it has focus so users will realize that the widget doesn't have focus and hence the key presses are getting lost? |
(0031573) Utkarsh Ayachit (administrator) 2013-09-16 11:58 |
SUMMARY --------------------------------------------- Topics merged into master: 14181_fix_link_camera 14274-fixup-catalyst 14275_fix_comparative_view 14276-hide-label-visibility (VTK) cosmotools-vtk-extensions (VTK) fix_segfault_on_invalid_input pvweb-state-loading |
(0031592) Alan Scott (manager) 2013-09-18 13:04 |
I am sure this bug has been fixed, with the exception of bug 14283, which just had bug fixes placed in Next. The update issues will be tested with that bug next week. Closing this one. Tested deleting of points remote server, Linux, master. |
2013-01-08 18:16 | Alan Scott | New Issue | |
2013-01-28 16:51 | Utkarsh Ayachit | Note Added: 0030267 | |
2013-01-28 16:51 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2013-01-28 16:51 | Utkarsh Ayachit | Fixed in Version | => git-next |
2013-01-28 16:51 | Utkarsh Ayachit | Resolution | open => fixed |
2013-01-28 16:51 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2013-01-28 16:53 | Utkarsh Ayachit | Topic Name | => 13776_fix_lut_updates |
2013-01-30 10:21 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2013-01-30 10:21 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-01-30 10:21 | Utkarsh Ayachit | Note Added: 0030277 | |
2013-01-30 10:40 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.1 |
2013-02-11 18:45 | Alan Scott | Note Added: 0030330 | |
2013-02-11 18:45 | Alan Scott | Status | customer review => todo |
2013-07-26 12:36 | Utkarsh Ayachit | Tag Attached: ColorMap | |
2013-09-12 13:18 | Utkarsh Ayachit | Note Added: 0031557 | |
2013-09-12 13:18 | Utkarsh Ayachit | Status | todo => gatekeeper review |
2013-09-16 11:57 | Utkarsh Ayachit | Fixed in Version | 3.98.1 => git-master |
2013-09-16 11:58 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-09-16 11:58 | Utkarsh Ayachit | Note Added: 0031573 | |
2013-09-18 13:02 | Alan Scott | Relationship added | related to 0014283 |
2013-09-18 13:04 | Alan Scott | Note Added: 0031592 | |
2013-09-18 13:04 | Alan Scott | Status | customer review => closed |
2013-11-01 13:18 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
2015-01-09 13:54 | Utkarsh Ayachit | Source_changeset_attached | => VTK master 56893c57 |
2015-01-09 13:55 | Utkarsh Ayachit | Source_changeset_attached | => VTK master fa104875 |
2015-01-09 13:55 | Utkarsh Ayachit | Source_changeset_attached | => VTK master 60e8c178 |
2015-01-11 08:28 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 7ac4db4d |
2015-01-11 08:28 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master a4166217 |
