0013766 | ParaView | (No Category) | public | 2013-01-02 15:20 | 2015-01-11 08:28 | ||||
Target Version | Fixed in Version | 3.98.1 | |||||||
Summary | 0013766: Error reading files with small timesteps | ||||||||
Description | Try loading the attached xmf file. ParaView doesn't seem to load anything. If however you change the xmf file to have time values of the order of 1e-02 instead of 1e-09, this start working again. | ||||||||
Project | Kitware | ||||||||
Topic Name | 13766_xdmf_small_timestep_bug | ||||||||
Attached Files | xdmf_particles1.xmf [^] (8,957 bytes) 2013-01-02 15:20 xdmf_particles1.h5 [^] (191,592 bytes) 2013-01-02 15:20 | ||||||||
(0029972) Utkarsh Ayachit (administrator) 2013-01-03 13:18 |
commit 1de65daaba340ae79231bd3d2ebab92c370b4a9b Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Thu Jan 3 13:09:52 2013 -0500 BUG 0013766. Fix issues with Xdmf reader for small timesteps. Xdmf reader was behaving oddly when timesteps were in the range (0, 1e-7). The problem was due to the XdmfTime::IsValid(...) matching multiple grids for such low values. That resulted in the data type for the reader changing in request data, hence producing empty data (BUG 0013766). Fixed by chaging the epsilon used for time comparisons and reporting error when the data type generated doesn't match the data type expected. Change-Id: If91fbb4934257ea99728b5ce964df1e790e17ec5 |
(0029986) Utkarsh Ayachit (administrator) 2013-01-04 14:46 |
merged into master, if applicable. |
(0029991) Utkarsh Ayachit (administrator) 2013-01-04 15:02 |
Merge topic '13766_xdmf_small_timestep_bug' into next b82a397 Bring in VTK fix for BUG 0013766. |
(0030112) Utkarsh Ayachit (administrator) 2013-01-11 14:43 |
merged into master, where applicable. |
(0030160) Alan Scott (manager) 2013-01-16 22:07 |
Tested Linux, master, local server. |
2013-01-02 15:20 | Utkarsh Ayachit | New Issue | |
2013-01-02 15:20 | Utkarsh Ayachit | File Added: xdmf_particles1.xmf | |
2013-01-02 15:20 | Utkarsh Ayachit | File Added: xdmf_particles1.h5 | |
2013-01-03 13:18 | Utkarsh Ayachit | Topic Name | => 13766_xdmf_small_timestep_bug |
2013-01-03 13:18 | Utkarsh Ayachit | Note Added: 0029972 | |
2013-01-03 13:18 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2013-01-03 13:18 | Utkarsh Ayachit | Resolution | open => fixed |
2013-01-03 13:18 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2013-01-04 14:45 | Utkarsh Ayachit | Fixed in Version | => git-master |
2013-01-04 14:46 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-01-04 14:46 | Utkarsh Ayachit | Note Added: 0029986 | |
2013-01-04 15:02 | Utkarsh Ayachit | Note Added: 0029991 | |
2013-01-04 15:02 | Utkarsh Ayachit | Status | customer review => gatekeeper review |
2013-01-11 14:43 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-01-11 14:43 | Utkarsh Ayachit | Note Added: 0030112 | |
2013-01-16 22:07 | Alan Scott | Note Added: 0030160 | |
2013-01-16 22:07 | Alan Scott | Status | customer review => closed |
2013-01-30 10:40 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.1 |
2015-01-09 14:01 | Utkarsh Ayachit | Source_changeset_attached | => VTK master 9270a476 |
2015-01-09 14:01 | Utkarsh Ayachit | Source_changeset_attached | => VTK master 1de65daa |
2015-01-11 08:28 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 9ed8acf2 |
2015-01-11 08:28 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master b82a397b |
