0013752ParaView(No Category)public2012-12-20 18:272013-05-18 20:00
ReporterKen Moreland
Assigned ToNikhil Shetty
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version
Target VersionFixed in Version4.0
Summary0013752: Move Selection Controls toolbar to above 3D view.
DescriptionThere has been a suggestion that we move the toolbar buttons in the Selection Controls toolbar away from the main toolbar and into the thin bar above a 3D view. This is where the selection buttons are for other view types like the line chart view.
It is debatable whether the selection buttons should be moved to the 3D toolbar. However, all the selections should be made consistent. That is, either the 3D selections should go to the 3D view bar, or the 2D selections should be moved to the main toolbar.
TagsNo tags attached.
ProjectSandia
Topic Name0013752-move-selection-toolbar-above-3d-view
Typeincorrect functionality
 Relationships
  Notes
(0030309)
Nikhil Shetty (reporter)
2013-02-06 12:20
The following were also done as part of this commit.
 - Disable SelectionControlToolbar.
 - Delete Undo Redo buttons from 3D view.
 - Move QueryData button to MainControlsToolbar.
 - Handle logic in a specilization of pqRubberBandHelper called
   pqSlection3DHelper.
The pqSlection3DHelper class does the following
 - Manages all selections
 - Ensures that only one selection is enabled at any given time.
 - Makes 3D interaction mode implicit (default).
 - Enables new behavior where selections can be pressed and released.
(0030337)
2013-02-13 10:19
SUMMARY
Topics merged into master:
        13263_prism_view_scaling
        13855_fix_segfault_on_loadstate
        improve-uncertainty-surface
        update_version_to_3.98.1-enhanced
(0030384)
Alan Scott (manager)
2013-02-26 16:22
Tested remote server, master, Linux.
 Issue History
2012-12-20 18:27 Ken Moreland New Issue
2013-01-08 21:26 Alan Scott Project TBD => Sandia
2013-01-24 22:37 Utkarsh Ayachit Assigned To => Nikhil Shetty
2013-01-29 13:29 Nikhil Shetty Status backlog => todo
2013-01-29 19:00 Nikhil Shetty Status todo => active development
2013-02-06 12:20 Nikhil Shetty Topic Name => 0013752-move-selection-toolbar-above-3d-view
2013-02-06 12:20 Nikhil Shetty Note Added: 0030309
2013-02-06 12:20 Nikhil Shetty Status active development => gatekeeper review
2013-02-13 10:18 Utkarsh Ayachit Fixed in Version => git-master
2013-02-13 10:19 Utkarsh Ayachit Status gatekeeper review => customer review
2013-02-13 10:19 Utkarsh Ayachit Note Added: 0030337
2013-02-26 16:22 Alan Scott Note Added: 0030384
2013-02-26 16:22 Alan Scott Status customer review => closed
2013-02-26 16:22 Alan Scott Resolution open => fixed
2013-05-18 20:00 Utkarsh Ayachit Fixed in Version git-master => 4.0
