0013749 | ParaView | (No Category) | public | 2012-12-20 12:48 | 2015-01-11 08:15 | ||||
Product Version | 3.98.0 | ||||||||
Target Version | Fixed in Version | 4.2 | |||||||
Summary | 0013749: Not obvious why volume rendering doesn't work remote server | ||||||||
Description | There is a confusion why remote server, volume rendering sometimes doesn't work. This is because remote server, local rendering doesn't volume render. If the dataset is small enough that ParaView tries to local render, it is just displayed as outline mode. Example: remote server, 3.98.0, Linux. Wavelet. Volume render. I think my preferred solution would be to force remote rendering for volume rendering. Since if the dataset size is large enough we automatically do this anyway, the user's setup should be able to handle this case correctly. Thoughts? | ||||||||
Project | Sandia | ||||||||
Topic Name | miscellaneous_volume_rendering_fixes | ||||||||
(0033365) Utkarsh Ayachit (administrator) 2014-09-17 12:38 |
commit c14d006f2df29551bc01a31d6c385ab10190c919 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Wed Sep 17 12:26:23 2014 -0400 BUG 0013749: Auto-detect remote-rendering requirements. Added support to vtkPVRenderView to enable representations to request either remote or local rendering. vtkImageVolumeRepresentation uses this new mechanism to tell the view that volume rendering requires remote rendering. Now, when in client-server (or distributed) mode, a volume rendering an image data, ParaView will automatically switch to remote rendering, if possible. When not possible, we also display an error message. Also updated ImageVolumeRendering test to no longer manually force remote-rendering. Change-Id: I973b55f6bcaa1348c9e6f9c1739334dfc3318c47 commit 637e13995af66199de4dadb9a4954b9355a171e5 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Wed Sep 17 12:08:58 2014 -0400 Fix lost string termination character. The code to send server-side messages to client was losing the string termination character resulting in the client showing trailing garbage. Fixed that. Change-Id: Ibd6aec9fdcc488e2e7cd7c9564461580d457c645 commit 28ce06c03b013cc99a40b198d6617d0f17dc5a59 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Wed Sep 17 12:00:25 2014 -0400 Fix detection of X. ParaView was using obsolete PARAVIEW_USE_X flag. That flag was removed during modularization changes. Fixed to use the proper VTK_USE_X flag to check if we should use X API. This now fixes the detection of a valid display on the server nodes. Change-Id: I9478f991f81825fd3809895a311a0d3ce4e82043 |
(0033367) Utkarsh Ayachit (administrator) 2014-09-17 14:17 |
Topics merged into master: miscellaneous_volume_rendering_fixes (VTK) vtkPolyData_removecells |
(0034046) Alan Scott (manager) 2015-01-09 14:45 |
Sweet. Tested Linux, remote server, 4.3.0 RC1. |
2012-12-20 12:48 | Alan Scott | New Issue | |
2014-09-17 12:14 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2014-09-17 12:38 | Utkarsh Ayachit | Topic Name | => miscellaneous_volume_rendering_fixes |
2014-09-17 12:38 | Utkarsh Ayachit | Note Added: 0033365 | |
2014-09-17 12:38 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2014-09-17 12:38 | Utkarsh Ayachit | Fixed in Version | => git-next |
2014-09-17 12:38 | Utkarsh Ayachit | Resolution | open => fixed |
2014-09-17 14:17 | Utkarsh Ayachit | Note Added: 0033367 | |
2014-09-17 14:17 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-09-17 14:17 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2014-09-24 10:13 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
2015-01-09 14:45 | Alan Scott | Note Added: 0034046 | |
2015-01-09 14:45 | Alan Scott | Status | customer review => closed |
2015-01-11 08:15 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master f1c4b1c9 |
2015-01-11 08:15 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 8da3053d |
