0013739 | ParaView | (No Category) | public | 2012-12-17 15:08 | 2015-01-11 08:28 | ||||
Product Version | 3.98.0 | ||||||||
Target Version | Fixed in Version | 3.98.1 | |||||||
Summary | 0013739: Group select of variables no longer works | ||||||||
Description | Selecting groups of variables no longer works. This needs to be corrected soon. * 3.98.0, local server, Linux. * Open can.exo. * Select ACCL. <shift> select DISPL. VEL should have also been selected. | ||||||||
Project | Sandia | ||||||||
Topic Name | 13739_fix_variable_selection | ||||||||
Relationships | |||||||||||
(0029962) Utkarsh Ayachit (administrator) 2012-12-31 12:05 |
commit 488b815dcf6f081a07fef37326f5c84a7ad70a05 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Mon Dec 31 12:02:04 2012 -0500 BUG 0013739. Enable changing check-state for multiple items. To make toggling of check-states for a bunch of items easier, we follow the style adopted by GMail: we change the state of all selected items to match the current items state. Change-Id: I3e277829264af073aeaf7ced3d2a7c6ce7a9e2a6 |
(0029983) Utkarsh Ayachit (administrator) 2013-01-04 14:46 |
merged into master, if applicable. |
(0029996) Alan Scott (manager) 2013-01-07 12:42 |
Master as of Friday late afternoon, Windows, local server. This doesn't work correctly. Do the following: Load can.exo. All variables on. Select the ACCL check box (not the text to the right of the check box). hold <shift> down Select the DISPL check box. Bug - VEL doesn't turn off. Selecting anywhere on the line should have the same effect. Note that there are two similar bugs here (related to each other). One is owned by Utkarsh and one by Dave. |
(0030005) Utkarsh Ayachit (administrator) 2013-01-08 11:29 |
commit 36c9d889af8150faf8b161472684b89c273e1759 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Tue Jan 8 11:24:33 2013 -0500 BUG 0013739. Fixes issues when user clicked on the check-box itself. Toggling the check-state of multiple items wasn't working correctly when the user clicked on the "checkbox" itself, rather than the name of the item. This fix address that issue. We make each of the items non-checkable. Thus Qt no longer deals with the check-box toggling. This results in the clicks on the "check-box" to be treated similar to clicks on the item's name. We have code that handles that already and hence everything works as expected. Now the perceived behaviour is identical whether the user click on the checkbox or its name in the variable selection widget. Change-Id: I30fb162788a8cf47214f72b92a91cbb1db6c9ff8 |
(0030111) Utkarsh Ayachit (administrator) 2013-01-11 14:43 |
merged into master, where applicable. |
(0030128) Alan Scott (manager) 2013-01-11 18:19 |
Fixed. Tested remote server, Linux, master. |
2012-12-17 15:08 | Alan Scott | New Issue | |
2012-12-18 13:53 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2012-12-18 13:53 | Utkarsh Ayachit | Status | backlog => todo |
2012-12-31 10:51 | Utkarsh Ayachit | Status | todo => active development |
2012-12-31 12:05 | Utkarsh Ayachit | Topic Name | => 13739_fix_variable_selection |
2012-12-31 12:05 | Utkarsh Ayachit | Note Added: 0029962 | |
2012-12-31 12:05 | Utkarsh Ayachit | Status | active development => gatekeeper review |
2012-12-31 12:05 | Utkarsh Ayachit | Fixed in Version | => git-next |
2012-12-31 12:05 | Utkarsh Ayachit | Resolution | open => fixed |
2012-12-31 12:05 | Utkarsh Ayachit | Relationship added | related to 0013629 |
2013-01-04 14:45 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2013-01-04 14:46 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-01-04 14:46 | Utkarsh Ayachit | Note Added: 0029983 | |
2013-01-07 12:42 | Alan Scott | Note Added: 0029996 | |
2013-01-07 12:42 | Alan Scott | Status | customer review => todo |
2013-01-08 10:30 | Utkarsh Ayachit | Status | todo => active development |
2013-01-08 11:29 | Utkarsh Ayachit | Note Added: 0030005 | |
2013-01-08 11:29 | Utkarsh Ayachit | Status | active development => gatekeeper review |
2013-01-11 14:43 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-01-11 14:43 | Utkarsh Ayachit | Note Added: 0030111 | |
2013-01-11 18:19 | Alan Scott | Note Added: 0030128 | |
2013-01-11 18:19 | Alan Scott | Status | customer review => closed |
2013-01-30 10:40 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.1 |
2013-02-27 18:00 | Alan Scott | Relationship added | has duplicate 0013918 |
2015-01-11 08:28 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 743aa595 |
2015-01-11 08:28 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 36c9d889 |
2015-01-11 08:28 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 39a0456a |
2015-01-11 08:28 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 488b815d |
