0013726ParaView(No Category)public2012-12-11 19:432015-01-11 08:29
ReporterAlan Scott
Assigned ToUtkarsh Ayachit
PriorityhighSeverityminorReproducibilityhave not tried
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version3.98.0
Target VersionFixed in Version3.98.1
Summary0013726: Extreme slowness turning on all variables
DescriptionA user has a dataset that is extremely slow selecting all variables. It takes numerous minutes, up to 10ish minutes. This Exodus dataset has hundreds of variables in it. I can give Utkarsh the file (Windows 7, output_wedge_presto_paraview_bug.e)
Open file.
Select all variables. Wait for numerous minutes. Issue seems to be in pqExodusIIVariableSelectionWidget::pqInternals(), called (indirectly) from pqExodusIIVariableSelectionWidget::propertyChanged(). Seems to be an event driven call, to a foreach loop, with an inner findItem loop, with an inner foreach loop.
Note that 3.14.0 selects all variables within about 5 seconds.
This bug has made ParaView 3.98.0 unusable for my user.
TagsNo tags attached.
ProjectSandia
Topic Name13726_fix_variable_selection_performance
Typeincorrect functionality
 Relationships
  Notes
(0029869)
Alan Scott (manager)
2012-12-11 19:43
Needed for 4.0
(0029878)
Kyle Lutz (viewer)
2012-12-12 17:04
Utkarsh is on vacation. Can you send the file to anyone else at Kitware? Otherwise we'll have to wait until Utkarsh gets back.
(0029879)
2012-12-12 18:31
file can be seen by anyone at Kitware. However, since this doesn't need to be fixed immediately (this week), I can just push to Utkarsh next week. Sound good, or is there a specific person you want it sent to?
(0029907)
2012-12-18 14:16
commit d8446c652c82c4eb88122c4f77a254afbcd4b10a
Date: Tue Dec 18 14:10:32 2012 -0500
    BUG 0013726. Fix variable selection performance.
    Addresses extreme slowness when dealing with lists containing large number of
    variables on panels such as exodus. Using a timer to collapse all updates into a
    single update thus avoiding the O(N^2) updates.
(0029934)
2012-12-21 11:21
merged into master, if applicable.
(0030002)
2013-01-07 21:13
edited on: 2013-01-07 21:24
This needs more fineness or polishing.
A common thing to do is as follows:
* Turn on all variables. (click the Variables button)
* No wait - I only want 15 variables on. (Click the Variables button)
* (Or, accidentally click the button twice, then again).
Try clicking on this button twice, and the second one freezes for over a minute.
(0030004)
2013-01-08 11:07
commit d428305797a386d6e5422876bc64512d024a50eb
Date: Tue Jan 8 11:04:23 2013 -0500
    BUG 0013726. Fixing performance issues with updating variables.
    This fixes the performance issue still observed after the supposed fix
    d8446c652c. The issue was that we were still ending up with a list that updated
    the item multiple times. Updating the internal datastructures to create the
    smallest possible list of items that need updating. This addresses the issue.
    Change-Id: I878c5171b9a174d51b0ac853adba6b05f77be66a
(0030109)
2013-01-11 14:43
merged into master, where applicable.
(0030126)
2013-01-11 18:16
This seems to have fixed it. Sweet!
Tested remote server, Linux, master.
 Issue History
2012-12-11 19:43 Alan Scott New Issue
2012-12-11 19:43 Alan Scott Note Added: 0029869
2012-12-11 19:43 Alan Scott Status backlog => todo
2012-12-12 16:49 Sebastien Jourdain Assigned To => Kyle Lutz
2012-12-12 17:04 Kyle Lutz Note Added: 0029878
2012-12-12 18:31 Alan Scott Note Added: 0029879
2012-12-18 14:16 Utkarsh Ayachit Topic Name => 13726_fix_variable_selection_performance, 13629_easy_exodus_variable_seln
2012-12-18 14:16 Utkarsh Ayachit Note Added: 0029907
2012-12-18 14:16 Utkarsh Ayachit Status todo => gatekeeper review
2012-12-18 14:16 Utkarsh Ayachit Fixed in Version => git-next
2012-12-18 14:16 Utkarsh Ayachit Resolution open => fixed
2012-12-18 14:16 Utkarsh Ayachit Assigned To Kyle Lutz => Utkarsh Ayachit
2012-12-19 09:55 Utkarsh Ayachit Topic Name 13726_fix_variable_selection_performance, 13629_easy_exodus_variable_seln => 13726_fix_variable_selection_performance, 13629_easy_exodus_variable_seln, remove_obsolete_files
2012-12-21 11:20 Utkarsh Ayachit Fixed in Version git-next => git-master
2012-12-21 11:21 Utkarsh Ayachit Status gatekeeper review => customer review
2012-12-21 11:21 Utkarsh Ayachit Note Added: 0029934
2013-01-07 21:13 Alan Scott Note Added: 0030002
2013-01-07 21:13 Alan Scott Status customer review => todo
2013-01-07 21:24 Alan Scott Note Edited: 0030002
2013-01-08 10:30 Utkarsh Ayachit Status todo => active development
2013-01-08 11:07 Utkarsh Ayachit Topic Name 13726_fix_variable_selection_performance, 13629_easy_exodus_variable_seln, remove_obsolete_files => 13726_fix_variable_selection_performance
2013-01-08 11:07 Utkarsh Ayachit Note Added: 0030004
2013-01-08 11:07 Utkarsh Ayachit Status active development => gatekeeper review
2013-01-08 11:07 Utkarsh Ayachit Fixed in Version git-master => git-next
2013-01-11 14:42 Utkarsh Ayachit Fixed in Version git-next => git-master
2013-01-11 14:43 Utkarsh Ayachit Status gatekeeper review => customer review
2013-01-11 14:43 Utkarsh Ayachit Note Added: 0030109
2013-01-11 18:16 Alan Scott Note Added: 0030126
2013-01-11 18:16 Alan Scott Status customer review => closed
2013-01-30 10:40 Utkarsh Ayachit Fixed in Version git-master => 3.98.1
2015-01-11 08:28 Utkarsh Ayachit Source_changeset_attached => ParaView master c9717e25
2015-01-11 08:28 Utkarsh Ayachit Source_changeset_attached => ParaView master d4283057
2015-01-11 08:29 Utkarsh Ayachit Source_changeset_attached => ParaView master 66684404
2015-01-11 08:29 Utkarsh Ayachit Source_changeset_attached => ParaView master dc331ccc
2015-01-11 08:29 Utkarsh Ayachit Source_changeset_attached => ParaView master d8446c65
