0013704ParaView(No Category)public2012-12-05 13:192016-08-12 09:59
ReporterOrion Poplawski
Assigned ToKitware Robot
StatusclosedResolutionmoved
PlatformOSOS Version
Product Version
Summary0013704: Allow setting SQTK_LIB_INSTALL_PATH
DescriptionI install paraview libraries into a different location with -DVTK_INSTALL_LIBRARY_DIR:PATH=lib64/paraview. However, SQTK_LIB_INSTALL_PATH does not honor this and there seems to be no way to change it.
Also, pvblot appears to use PV_INSTALL_{BIN,LIB}_DIR, but I'm not sure about the status of those macros:
# for temporary backwards compatibility.
set (PV_INSTALL_BIN_DIR ${VTK_INSTALL_RUNTIME_DIR})
set (PV_INSTALL_LIB_DIR ${VTK_INSTALL_ARCHIVE_DIR})
TagsNo tags attached.
ProjectTBD
Topic Name
Typeincorrect functionality
 Relationships
  Notes
(0038290)
Kitware Robot (administrator)
2016-08-12 09:59
Resolving issue as `moved`.
 Issue History
2012-12-05 13:19 Orion Poplawski New Issue
2016-08-12 09:59 Kitware Robot Note Added: 0038290
2016-08-12 09:59 Kitware Robot Status backlog => closed
2016-08-12 09:59 Kitware Robot Resolution open => moved
2016-08-12 09:59 Kitware Robot Assigned To => Kitware Robot
