0013675 | ParaView | (No Category) | public | 2012-11-24 09:19 | 2015-01-11 08:28 | ||||
Assigned To | Nikhil Shetty | ||||||||
Target Version | Fixed in Version | 3.98.1 | |||||||
Summary | 0013675: Update mpi4py to the latest version available | ||||||||
Description | Update mpi4py to the latest version available. Start with the CMakeLists.txt that are provided in the source for mpi4py itself. Also add test for the same. | ||||||||
Project | Kitware | ||||||||
Topic Name | 0013675-update-mpi4py-1.3 | ||||||||
Relationships | ||||||
(0029925) Utkarsh Ayachit (administrator) 2012-12-21 11:21 |
merged into master, if applicable. |
(0029949) Utkarsh Ayachit (administrator) 2012-12-24 16:34 |
reopening since this is causing failure with building binaries on Mac/Linux. |
(0029950) Utkarsh Ayachit (administrator) 2012-12-24 16:39 |
commit 18bd00fc77d23e2d0b7e48bdd7f293ee49500630 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Mon Dec 24 16:35:00 2012 -0500 BUG 0013675. Fix issues building mpi4py. - Compiler definitions were not added the right way, this was causing build errors on blight since it failed to recognize "-D foo" arguments. Fixed that by using add_definitions() which is the standard way of adding compiler definitions. - Cleaned up cmake file to not use deprecated MPI_* variables. Use MPI_C_*, MPI_CXX_* instead. Also using the compilers found by find_package(MPI) for configuring the mpi.cfg file rather than doing the find_program() calls which may end up picking different compilers. - Cleaned up cmake file to not use "echo" instead configure the generated files. This will work more robustly across all platforms. Change-Id: I1bf22eb4b920c6a2fc44000a78f3f941cab53ab3 |
(0029951) Utkarsh Ayachit (administrator) 2012-12-25 08:44 |
merged into master. |
(0030166) Alan Scott (manager) 2013-01-16 22:29 |
Tested by developers, and this is basically a developer tag in git. |
2012-11-24 09:19 | Utkarsh Ayachit | New Issue | |
2012-11-24 09:19 | Utkarsh Ayachit | Assigned To | => Nikhil Shetty |
2012-11-24 09:34 | Utkarsh Ayachit | Relationship added | related to 0013587 |
2012-12-12 11:55 | Nikhil Shetty | Status | backlog => todo |
2012-12-14 19:14 | Nikhil Shetty | Status | todo => active development |
2012-12-19 21:09 | Nikhil Shetty | Topic Name | => 0013675-update-mpi4py-1.3 |
2012-12-20 13:38 | Nikhil Shetty | Status | active development => gatekeeper review |
2012-12-21 11:20 | Utkarsh Ayachit | Fixed in Version | => git-master |
2012-12-21 11:21 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-12-21 11:21 | Utkarsh Ayachit | Note Added: 0029925 | |
2012-12-24 16:34 | Utkarsh Ayachit | Note Added: 0029949 | |
2012-12-24 16:34 | Utkarsh Ayachit | Status | customer review => backlog |
2012-12-24 16:34 | Utkarsh Ayachit | Resolution | open => reopened |
2012-12-24 16:39 | Utkarsh Ayachit | Note Added: 0029950 | |
2012-12-24 16:39 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2012-12-24 16:39 | Utkarsh Ayachit | Resolution | reopened => fixed |
2012-12-25 08:44 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-12-25 08:44 | Utkarsh Ayachit | Note Added: 0029951 | |
2013-01-16 22:29 | Alan Scott | Note Added: 0030166 | |
2013-01-16 22:29 | Alan Scott | Status | customer review => closed |
2013-01-30 10:40 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.1 |
2015-01-11 08:28 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 591916f9 |
2015-01-11 08:28 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 18bd00fc |
