0013654ParaView(No Category)public2012-11-13 17:082013-01-30 10:41
ReporterOrion Poplawski
Assigned ToNikhil Shetty
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version
Target VersionFixed in Version3.98.1
Summary0013654: cmake error configuring pvblot plugin
DescriptionTrying to build 3.98.0 for Fedora, getting:
-- Plugin: pvblot - PVBLOT Plugin : Enabled
CMake Error: Could not open file for write in copy operation /pvblot.tmp
CMake Error: : System Error: Permission denied
CMake Error at Plugins/pvblot/CMakeLists.txt:77 (CONFIGURE_FILE):
  configure_file Problem configuring file
from Plugins/pvblot/CMakeLists.txt:
CONFIGURE_FILE(
  "${CMAKE_CURRENT_SOURCE_DIR}/pvblot${script_exe}.in"
  "${EXECUTABLE_OUTPUT_PATH}/pvblot${script_exe}"
  @ONLY
So it appears that ${EXECUTABLE_OUTPUT_PATH} is not set in this case.
cmake line is:
/usr/bin/cmake -DCMAKE_VERBOSE_MAKEFILE=ON -DCMAKE_INSTALL_PREFIX:PATH=/usr -DINCLUDE_INSTALL_DIR:PATH=/usr/include -DLIB_INSTALL_DIR:PATH=/usr/lib64 -DSYSCONF_INSTALL_DIR:PATH=/etc -DSHARE_INSTALL_PREFIX:PATH=/usr/share -DLIB_SUFFIX=64 -DBUILD_SHARED_LIBS:BOOL=ON .. -DPV_INSTALL_INCLUDE_DIR:PATH=include/paraview -DPV_INSTALL_LIB_DIR:PATH=lib64/paraview -DCMAKE_CXX_COMPILER:FILEPATH=g++ -DCMAKE_C_COMPILER:FILEPATH=gcc -DTCL_LIBRARY:PATH=tcl -DTK_LIBRARY:PATH=tk -DPARAVIEW_BUILD_PLUGIN_AdiosReader:BOOL=ON -DPARAVIEW_BUILD_PLUGIN_CoProcessingScriptGenerator:BOOL=ON -DPARAVIEW_BUILD_PLUGIN_EyeDomeLighting:BOOL=ON -DPARAVIEW_BUILD_PLUGIN_ForceTime:BOOL=ON -DPARAVIEW_ENABLE_PYTHON:BOOL=ON -DPARAVIEW_INSTALL_THIRD_PARTY_LIBRARIES:BOOL=OFF -DPARAVIEW_INSTALL_DEVELOPMENT:BOOL=ON -DVTK_OPENGL_HAS_OSMESA:BOOL=ON -DVTK_USE_BOOST:BOOL=ON -DVTK_USE_INFOVIS:BOOL=OFF -DVTK_USE_N_WAY_ARRAYS:BOOL=ON -DVTK_USE_OGGTHEORA_ENCODER:BOOL=ON -DVTK_USE_SYSTEM_LIBRARIES=ON -DVTK_USE_SYSTEM_HDF5=ON -DHDF5_HL_LIBRARY:FILEPATH=/usr/lib64/libhdf5_hl.so -DVTK_USE_SYSTEM_LIBPROJ4=OFF -DVTK_USE_SYSTEM_QTTESTING=OFF -DVTK_USE_SYSTEM_XDMF2=OFF -DXDMF_WRAP_PYTHON:BOOL=ON -DBUILD_DOCUMENTATION:BOOL=ON -DBUILD_EXAMPLES:BOOL=ON
TagsNo tags attached.
ProjectTBD
Topic Name0013654-fix-pvblot-plugin-CMakeLists.txt
Typeincorrect functionality
 Relationships
  Notes
(0029868)
Nikhil Shetty (reporter)
2012-12-11 15:57
There is another configure step below. ${EXECUTABLE_OUTPUT_PATH} is unpredictable and so the later with {ParaView_BINARY_DIR} is preferred.
(0029892)
Sebastien Jourdain (manager)
2012-12-14 13:33
Merged to master
(0029894)
Orion Poplawski (reporter)
2012-12-15 18:53
Looks good to me. Thanks!
 Issue History
2012-11-13 17:08 Orion Poplawski New Issue
2012-11-24 09:25 Utkarsh Ayachit Assigned To => Nikhil Shetty
2012-12-11 15:57 Nikhil Shetty Topic Name => 0013654-fix-pvblot-plugin-CMakeLists.txt
2012-12-11 15:57 Nikhil Shetty Note Added: 0029868
2012-12-11 15:57 Nikhil Shetty Status backlog => todo
2012-12-11 15:57 Nikhil Shetty Status todo => active development
2012-12-11 15:58 Nikhil Shetty Status active development => gatekeeper review
2012-12-14 13:33 Sebastien Jourdain Status gatekeeper review => customer review
2012-12-14 13:33 Sebastien Jourdain Note Added: 0029892
2012-12-15 18:53 Orion Poplawski Note Added: 0029894
2012-12-15 18:54 Orion Poplawski Status customer review => closed
2012-12-15 18:54 Orion Poplawski Resolution open => fixed
2012-12-15 18:54 Orion Poplawski Fixed in Version => git-master
2013-01-30 10:41 Utkarsh Ayachit Fixed in Version git-master => 3.98.1
