0013645 | ParaView | (No Category) | public | 2012-11-12 13:13 | 2015-09-06 12:17 | ||||
Assigned To | Schuyler Kylstra | ||||||||
Product Version | 3.98.0 | ||||||||
Target Version | 4.4 | Fixed in Version | 4.4 | ||||||
Summary | 0013645: Add annotation of system info | ||||||||
Description | It would be really nice to have an annotation source that will display such things as file name and time and date. System name and number of processes would be really nice also. Each of these should be user seletable. | ||||||||
Project | Sandia | ||||||||
Type | feature | ||||||||
Attached Files | visitScreenshot.jpg [^] (303,971 bytes) 2015-06-17 16:27 ScreenShot.png [^] (194,291 bytes) 2015-06-30 16:52 | ||||||||
Relationships | |||||||||||
(0034009) Alan Scott (manager) 2014-12-23 18:14 |
Also, optionally add user name. |
(0034572) Schuyler Kylstra (developer) 2015-06-17 15:31 |
Could you explain what you're looking for in a little more detail? would this be a widget or a pop-up or something else entirely? Is this for each object in paraview or for the session as a whole? |
(0034575) Alan Scott (manager) 2015-06-17 16:19 |
Attached is a screenshot from default VisIt. Although I really don't like their defaults, what they provide has a lot of power as an option. These include who, when, what of this image. We should provide this as an option. Let me know if you need more detail. |
(0034576) Schuyler Kylstra (developer) 2015-06-17 16:26 |
Would the annotation be visible at all times or only in screenshots? |
(0034577) Alan Scott (manager) 2015-06-17 16:33 |
At all times, interactive and screenshots. It should look the same when the user sets up the image and what he/she has through file/ save screenshot. The image I attached is a screen grab of my windows box. If you don't think this makes sense, lets discuss. |
(0034578) Alan Scott (manager) 2015-06-17 16:34 |
By the way, I don't care how this is done - Properties tab or source... |
(0034579) Schuyler Kylstra (developer) 2015-06-17 16:44 |
I agree it makes sense. I was just thinking about style but if all the features are toggle-able then it wouldn't be a problem. |
(0034635) Schuyler Kylstra (developer) 2015-06-30 16:53 |
I uploaded an example screenshot. Is that what you had in mind? |
(0034684) Alan Scott (manager) 2015-07-07 21:37 |
Yes, very close to what I want. Does it make sense to keep include the directory? Makes it noisy... Ask Utkarsh his thoughts? |
(0034693) Utkarsh Ayachit (administrator) 2015-07-08 09:51 |
Maybe we can add a checkbox to say whether we're using the full path on only the filename. I am sure someone will ask for the case we won't implement soon enough :). |
(0034699) Alan Scott (manager) 2015-07-08 12:43 |
Agreed. Please make the modification Utkarsh suggested, and then move the bug back to gatekeeper review. |
(0034980) Utkarsh Ayachit (administrator) 2015-08-13 00:52 |
merged in master. |
(0035145) Utkarsh Ayachit (administrator) 2015-09-02 20:00 |
Testing notes: Current implementation is implemented as a filter (to allow for annotating the file name). e.g. + Open can.ex2, Apply + Create "Environment Annotation" filter (available under the "Annotation" group in Filters menu). + Simply check all checkboxes on the Properties panel and you'll see the annotation rendered in the Render View. |
(0035146) Alan Scott (manager) 2015-09-02 20:02 |
Tested master, Linux, remote server. |
2012-11-12 13:13 | Alan Scott | New Issue | |
2012-12-19 07:56 | Utkarsh Ayachit | Assigned To | => Nikhil Shetty |
2013-06-05 16:30 | Nikhil Shetty | Assigned To | Nikhil Shetty => |
2014-12-23 18:14 | Alan Scott | Note Added: 0034009 | |
2014-12-23 18:20 | Alan Scott | Relationship added | related to 0015226 |
2014-12-24 18:48 | Alan Scott | Target Version | => 4.4 |
2015-06-08 14:34 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2015-06-08 14:34 | Utkarsh Ayachit | Status | backlog => todo |
2015-06-08 14:53 | Utkarsh Ayachit | Assigned To | Utkarsh Ayachit => Schuyler Kylstra |
2015-06-17 15:31 | Schuyler Kylstra | Note Added: 0034572 | |
2015-06-17 16:19 | Alan Scott | Note Added: 0034575 | |
2015-06-17 16:19 | Alan Scott | File Added: visitScreenshot.jpg | |
2015-06-17 16:22 | Alan Scott | File Deleted: visitScreenshot.jpg | |
2015-06-17 16:23 | Alan Scott | File Added: visitScreenshot.jpg | |
2015-06-17 16:26 | Schuyler Kylstra | Note Added: 0034576 | |
2015-06-17 16:27 | Alan Scott | File Deleted: visitScreenshot.jpg | |
2015-06-17 16:27 | Alan Scott | File Added: visitScreenshot.jpg | |
2015-06-17 16:33 | Alan Scott | Note Added: 0034577 | |
2015-06-17 16:34 | Alan Scott | Note Added: 0034578 | |
2015-06-17 16:44 | Schuyler Kylstra | Note Added: 0034579 | |
2015-06-18 09:57 | Schuyler Kylstra | Status | todo => active development |
2015-06-30 11:08 | Schuyler Kylstra | Status | active development => gatekeeper review |
2015-06-30 11:08 | Schuyler Kylstra | Resolution | open => fixed |
2015-06-30 16:52 | Schuyler Kylstra | File Added: ScreenShot.png | |
2015-06-30 16:53 | Schuyler Kylstra | Note Added: 0034635 | |
2015-07-07 21:37 | Alan Scott | Note Added: 0034684 | |
2015-07-08 09:51 | Utkarsh Ayachit | Note Added: 0034693 | |
2015-07-08 12:43 | Alan Scott | Note Added: 0034699 | |
2015-07-08 21:46 | Alan Scott | Relationship added | related to 0015089 |
2015-08-13 00:52 | Utkarsh Ayachit | Note Added: 0034980 | |
2015-08-13 00:52 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2015-08-13 00:52 | Utkarsh Ayachit | Fixed in Version | => git-master |
2015-09-02 20:00 | Utkarsh Ayachit | Note Added: 0035145 | |
2015-09-02 20:02 | Alan Scott | Note Added: 0035146 | |
2015-09-02 20:02 | Alan Scott | Status | customer review => closed |
2015-09-06 12:17 | Utkarsh Ayachit | Fixed in Version | git-master => 4.4 |
