0013631 | ParaView | (No Category) | public | 2012-11-08 10:58 | 2016-08-12 09:59 | ||||
Reporter | Joe Borg | ||||||||
Summary | 0013631: Python trace does not pick up the XML color scale import method | ||||||||
Description | If you do a "Start Python Trace", followed by "Edit color map" -> "Choose preset" -> "Import", you only get the RGBPoints list, not the method used to convert the XML file into this list. Seeing as I can't find this method anywhere else, it would be useful for the trace to pick it up as I want to do it in batch. | ||||||||
Tags | PythonTrace | ||||||||
Project | TBD | ||||||||
Type | usability | ||||||||
(0038276) Kitware Robot (administrator) 2016-08-12 09:59 |
2012-11-08 10:58 | Joe Borg | New Issue | |
2014-07-04 21:49 | Utkarsh Ayachit | Tag Attached: PythonTrace | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038276 | |
