0013608 | ParaView | (No Category) | public | 2012-11-05 21:29 | 2013-01-30 10:41 | ||||
Assigned To | David Thompson | ||||||||
Target Version | Fixed in Version | 3.98.1 | |||||||
Summary | 0013608: Add a toolbar for Data Analysis plots | ||||||||
Description | Add a toolbar for plot over line, plot selection over time, plot global variables over time, extract selection. | ||||||||
Project | Sandia | ||||||||
Topic Name | 13608_data_analysis_toolbar | ||||||||
Type | feature | ||||||||
(0029911) David Thompson (developer) 2012-12-19 12:58 |
Just these 4 filters, or should the entire "Filters→Data Analysis" menu be included on the toolbar? |
(0029921) David Thompson (developer) 2012-12-21 09:17 |
Added a "Data Analysis" toolbar with plot over line, plot selection over time, plot global variables over time, extract selection. Also put ProbePoint in the toolbar. Since these filters were a subset of the Filters→Data Analysis menu, added some tags to ParaViewFilters.xml to allow toolbars to omit some filters. SVG source for new icons is in Qt/Components/Resources/Icons/pvIcons_dataAnalysis.svg. Also, since the new toolbar changed window geometries and caused test failures, another tag was added to ParaViewFilters.xml to allow generated toolbars to be turned off by default when tests are recorded and played. |
(0029930) Utkarsh Ayachit (administrator) 2012-12-21 11:21 |
merged into master, if applicable. |
(0030023) Alan Scott (manager) 2013-01-08 21:01 |
Very nice. Tested remote server, Linux, master. |
2012-11-05 21:29 | Alan Scott | New Issue | |
2012-11-05 21:30 | Alan Scott | Type | incorrect functionality => feature |
2012-12-11 09:51 | Sebastien Jourdain | Assigned To | => David Thompson |
2012-12-19 12:58 | David Thompson | Note Added: 0029911 | |
2012-12-21 09:17 | David Thompson | Topic Name | => 13608_data_analysis_toolbar |
2012-12-21 09:17 | David Thompson | Note Added: 0029921 | |
2012-12-21 09:17 | David Thompson | Status | backlog => gatekeeper review |
2012-12-21 09:17 | David Thompson | Fixed in Version | => git-next |
2012-12-21 09:17 | David Thompson | Resolution | open => fixed |
2012-12-21 11:20 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2012-12-21 11:21 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-12-21 11:21 | Utkarsh Ayachit | Note Added: 0029930 | |
2013-01-08 21:01 | Alan Scott | Note Added: 0030023 | |
2013-01-08 21:01 | Alan Scott | Status | customer review => closed |
2013-01-30 10:41 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.1 |
