0013587 | ParaView | (No Category) | public | 2012-10-29 21:13 | 2013-01-30 10:41 | ||||
Assigned To | Nikhil Shetty | ||||||||
Target Version | 3.98.0 | Fixed in Version | 3.98.1 | ||||||
Summary | 0013587: MPIPython fails to build on certain Macs | ||||||||
Description | Refer to this mailing list thread: http://www.paraview.org/pipermail/paraview/2012-August/025740.html [^] | ||||||||
Project | TBD | ||||||||
Topic Name | 0013675-update-mpi4py-1.3 => 13587_fix_mpi4py_build_issues | ||||||||
Relationships | ||||||
(0029582) Utkarsh Ayachit (administrator) 2012-10-29 21:15 |
Built target paraview_mpi_pyc Linking CXX shared module ../../../bin/MPIPython.so Undefined symbols for architecture x86_64: "_lt_dladvise_destroy", referenced from: _dlopen_mpi_lib in MPI.c.o "_lt_dladvise_ext", referenced from: _dlopen_mpi_lib in MPI.c.o "_lt_dladvise_global", referenced from: _dlopen_mpi_lib in MPI.c.o "_lt_dladvise_init", referenced from: _dlopen_mpi_lib in MPI.c.o "_lt_dlclose", referenced from: ___pyx_pf_6mpi4py_3MPI_Finalize in MPI.c.o ___pyx_f_6mpi4py_3MPI_atexit_py in MPI.c.o "_lt_dlexit", referenced from: ___pyx_pf_6mpi4py_3MPI_Finalize in MPI.c.o ___pyx_f_6mpi4py_3MPI_atexit_py in MPI.c.o "_lt_dlinit", referenced from: _dlopen_mpi_lib in MPI.c.o "_lt_dlopenadvise", referenced from: _dlopen_mpi_lib in MPI.c.o ld: symbol(s) not found for architecture x86_64 clang: error: linker command failed with exit code 1 (use -v to see invocation) |
(0029583) Utkarsh Ayachit (administrator) 2012-10-29 21:16 |
commit 0c83cfc18e8f87b2fbc51a4058cdb5e246f06c3d Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Mon Oct 29 21:14:08 2012 -0400 BUG 0013587. Fix mpi4py build issues. mpi4py was not linking against the MPI_CXX_LIBRARIES which was raising the compilers errors with certain mpi implementations. Change-Id: Ie47e6b1c5df9c385b1de25b2b2d7b73af2ea6c68 |
(0029584) Utkarsh Ayachit (administrator) 2012-10-29 22:42 |
The commit doesn't fix the issue. We need to update the mpi4py version: http://code.google.com/p/mpi4py/issues/detail?id=9 [^] |
(0029881) Nikhil Shetty (reporter) 2012-12-13 10:07 |
Trying to first fix 0013675 and see if this issue gets fixed automatically |
(0029919) Nikhil Shetty (reporter) 2012-12-20 13:40 |
This is fixed in 0013675-update-mpi4py-1.3 |
(0029926) Utkarsh Ayachit (administrator) 2012-12-21 11:21 |
merged into master, if applicable. |
(0030047) Alan Scott (manager) 2013-01-09 16:22 |
Closing without testing. If this is still an issue, please reopen this bug (or create a new one). |
2012-10-29 21:13 | Utkarsh Ayachit | New Issue | |
2012-10-29 21:15 | Utkarsh Ayachit | Note Added: 0029582 | |
2012-10-29 21:16 | Utkarsh Ayachit | Topic Name | => 13587_fix_mpi4py_build_issues |
2012-10-29 21:16 | Utkarsh Ayachit | Note Added: 0029583 | |
2012-10-29 21:16 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2012-10-29 21:16 | Utkarsh Ayachit | Fixed in Version | => git-next |
2012-10-29 21:16 | Utkarsh Ayachit | Resolution | open => fixed |
2012-10-29 21:16 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2012-10-29 21:16 | Utkarsh Ayachit | Target Version | => 3.98.0 |
2012-10-29 22:42 | Utkarsh Ayachit | Note Added: 0029584 | |
2012-10-29 22:42 | Utkarsh Ayachit | Status | gatekeeper review => backlog |
2012-10-29 22:42 | Utkarsh Ayachit | Resolution | fixed => reopened |
2012-11-24 09:33 | Utkarsh Ayachit | Assigned To | Utkarsh Ayachit => Nikhil Shetty |
2012-11-24 09:34 | Utkarsh Ayachit | Relationship added | related to 0013675 |
2012-12-13 10:06 | Nikhil Shetty | Status | backlog => todo |
2012-12-13 10:07 | Nikhil Shetty | Note Added: 0029881 | |
2012-12-14 19:13 | Nikhil Shetty | Status | todo => active development |
2012-12-20 13:40 | Nikhil Shetty | Topic Name | 13587_fix_mpi4py_build_issues => 0013675-update-mpi4py-1.3 => 13587_fix_mpi4py_build_issues |
2012-12-20 13:40 | Nikhil Shetty | Note Added: 0029919 | |
2012-12-20 13:40 | Nikhil Shetty | Status | active development => gatekeeper review |
2012-12-21 11:20 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2012-12-21 11:21 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-12-21 11:21 | Utkarsh Ayachit | Note Added: 0029926 | |
2013-01-08 19:31 | Alan Scott | Project | Sandia => TBD |
2013-01-09 16:22 | Alan Scott | Note Added: 0030047 | |
2013-01-09 16:22 | Alan Scott | Status | customer review => closed |
2013-01-09 16:22 | Alan Scott | Resolution | reopened => fixed |
2013-01-30 10:41 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.1 |
