0013586 | ParaView | (No Category) | public | 2012-10-29 15:37 | 2012-10-31 20:14 | ||||
Assigned To | Sebastien Jourdain | ||||||||
Target Version | Fixed in Version | 3.98.0 | |||||||
Summary | 0013586: Bad rendering, multiple remote servers | ||||||||
Description | There is a visual artifact that has appeared in ParaView, multiple server. Replicate as follows: * Master, 8 servers, Linux. Utkarsh has replicated this with 3 servers. * Set remote rendering threshold to 0 (always remote render.) * Sources/ Wavelet. Whole extent as follows: -100, 10 -10, 10 -10, 10 * Reset. * +Z <<The bug appears as a few niches out of the block, top and bottom.>> * To see the bug better, zoom in and roll the block around. I am rotating around the X axis. I will attach a screenshot. Must be fixed for 4.0. | ||||||||
Project | Sandia | ||||||||
Topic Name | 13469_fix_cube_axes_parallel_rendering | ||||||||
Attached Files | waveletRenderBug.png [^] (190,840 bytes) 2012-10-29 15:40
(0029598) Sebastien Jourdain (manager) 2012-10-30 13:25 |
commit a69ccb68ff7c4badb4d246492bc2768992680188 Author: Sebastien Jourdain <sebastien.jourdain@kitware.com> Date: Tue Oct 30 09:03:18 2012 -0400 Fix bug 13586 in IceT compositing Change-Id: I883d1531299642bc4ce06419b8827d1edf24bc3c diff --git a/ParaViewCore/VTKExtensions/Rendering/vtkIceTCompositePass.cxx b/ParaViewCore/VTKExtensions/Rendering/vtkIceTCompositePass.cxx index ed5a409..76016ae 100644 --- a/ParaViewCore/VTKExtensions/Rendering/vtkIceTCompositePass.cxx +++ b/ParaViewCore/VTKExtensions/Rendering/vtkIceTCompositePass.cxx @@ -59,11 +59,8 @@ namespace void MergeCubeAxesBounds(double bounds[6], const vtkRenderState* rState) { vtkBoundingBox bbox(bounds); - // scale the bounds a bit so that when showing a box we don't end up with - // clipped edges e.g. when a Mandelbrot source was shown with parallel - // rendering, the front edges would appear clipped in outline mode. - bbox.Scale(1.1, 1.1, 1.1); + // Hande CubeAxes specifically has it wrongly implement the GetBounds() for (int cc=0; cc < rState->GetPropArrayCount(); cc++) { vtkProp* prop = rState->GetPropArray()[cc]; @@ -71,13 +68,11 @@ namespace if (cubeAxes != NULL && prop->GetVisibility() && prop->GetUseBounds()) { - // cubeAxes has not clean API to give us the bounds it's using. So, we - // use a heuristic instead. Simply scale the data bounds by 1.5 and we - // call it 'even'. - bbox.Scale(1.5, 1.5, 1.5); - break; + // Use custom bounds API for cube axes to embed titles and labels + bbox.AddBounds(cubeAxes->GetRenderedBounds()); } } + bbox.GetBounds(bounds); } }; diff --git a/VTK b/VTK index ff48698..907a59e 160000 --- a/VTK +++ b/VTK @@ -1 +1 @@ -Subproject commit ff4869841ec6016a5f8a73dc9b9703bc419c7b2f +Subproject commit 907a59e775a94c951c38785821167009ab440cfc |
(0029602) Sebastien Jourdain (manager) 2012-10-30 13:48 |
This issue was introduced when we scaled up by 1.1 the bounds of the actors to hopefully embed the cubeaxes labels. Unfortunately, by doing so, each partition used within IceT would receive none matching range which will trick IceT to do invalid compositing. Which is not the case when we inflate the bounds of only the cube axes. As the cube axes endup on all iceT partitions with exactly the same bounds... |
(0029616) Utkarsh Ayachit (administrator) 2012-10-31 10:47 |
merged into master, if applicable. |
(0029637) Alan Scott (manager) 2012-10-31 20:14 |
Tested with directions below. Linux, 8 remote servers, master. |
2012-10-29 15:37 | Alan Scott | New Issue | |
2012-10-29 15:40 | Alan Scott | File Added: waveletRenderBug.png | |
2012-10-29 15:41 | Utkarsh Ayachit | Assigned To | => Sebastien Jourdain |
2012-10-30 09:04 | Sebastien Jourdain | Topic Name | => 13469_fix_cube_axes_parallel_rendering |
2012-10-30 09:04 | Sebastien Jourdain | Status | backlog => gatekeeper review |
2012-10-30 09:04 | Sebastien Jourdain | Resolution | open => fixed |
2012-10-30 13:25 | Sebastien Jourdain | Note Added: 0029598 | |
2012-10-30 13:48 | Sebastien Jourdain | Note Added: 0029602 | |
2012-10-31 10:46 | Utkarsh Ayachit | Fixed in Version | => 3.98.0 |
2012-10-31 10:47 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-10-31 10:47 | Utkarsh Ayachit | Note Added: 0029616 | |
2012-10-31 20:14 | Alan Scott | Note Added: 0029637 | |
2012-10-31 20:14 | Alan Scott | Status | customer review => closed |
